C7 hitch
Old Sep 12, 2025 | 09:46 AM
Family Time's Avatar
Family Time
Default C7 hitch
I am trying to find a hitch for my car so I can make a small aluminum rack for some luggage. I have been all over the web and yet to find one I can get soon.
Popular Reply
Sep 12, 2025, 12:18 PM
ChiefBoats's Avatar
ChiefBoats
T2T SUPPORTER
Veteran: Coast Guard
From: NNCC No Name Car Crew; Owned 1 C2, 2 C3's, 1 C4, 3 C5's, 1 C6, 2 C7's; Now '86, '03; S. DE
2023 C3 of the Year Wnner - Unmodified
St. Jude Donor '21-'22-'23-'24-'25-'26
Leroy Engineering.
Old Sep 12, 2025 | 11:25 AM
Flattman's Avatar
Flattman
https://www.corvetteforum.com/forums...ler-hitch.html
Old Sep 12, 2025 | 12:18 PM
ChiefBoats's Avatar
ChiefBoats
T2T SUPPORTER
Leroy Engineering.
Old Sep 12, 2025 | 03:33 PM
Family Time
I called them and there is none available.Thx for the idea so far u haul is the only one that will make but I would not get it till mid November.I am leaving mid October.
Old Sep 12, 2025 | 10:37 PM
Vette Jockey's Avatar
Vette Jockey
Roadster Madness. 😠
St. Jude Donor '13, '20-'21
Originally Posted by ChiefBoats
Leroy Engineering.
Color me impressed, Chief!!! Bravo Zulu!!!
Old Sep 13, 2025 | 01:21 AM
ChiefBoats - that hitch looks great and fits very well.
Old Sep 13, 2025 | 06:34 AM
449er's Avatar
449er
CF Community Team
I guess it's worth saying, Corvettes are not designed or intended to tow anything
Old Sep 13, 2025 | 07:07 AM
BuckySti's Avatar
BuckySti
I saw this at the Corvette caravan last year. I had mixed feelings, on one hand, thinking what was said above about a Corvette towing something. On the other hand, trying to pack enough into a Corvette for two people traveling for 10 days.
Old Sep 13, 2025 | 10:35 AM
Gearhead Jim's Avatar
Gearhead Jim
St. Jude Donor '13
Don't use a C8, use a C7. We've been taking long road trips of 2-3 weeks in our various C5/C6/C7 Corvettes over the last 25 years, and it works well. Some trips up to 3 months, but that obviously requires doing laundry along the way.
The C8 looses some space by the numbers, and the C8 space is more difficult to use efficiently.
With any 'vette, pack carefully at home and then take pictures of the trunk(s) so you can get the stuff back in later.
Some "Expectation Management" is required- you can't take everything you want, but you can take everything you need.
Enjoy the trip!
Old Sep 13, 2025 | 11:47 AM
Ratboy's Avatar
Ratboy
There are some youtube videos showing custom installs, which I think is the only option if you need something right away, but you'll need some basic fabrication skills. I did mine similar to the Cody's Custom Creations video, but I stiffened up the cross member considerably using some 1/4" steel plates and spacers inside. Its so thin and brittle I think it would crack the way he did it. I don't have a welder, so I bought a hitch similar to the one he made but class II, and trimmed it to fit behind the license plate, plus mine has the holes for safety chains. I used a spring loaded license plate mount which makes it easy to r&r.
I've towed my trailers all over the place with over 1,000 lbs loaded (balanced to keep the tongue weight under 200 lbs.), and so far after three years and 40k miles (60k total), there are no cracks or other issues. My trans temp goes up about 20-30 degrees after awhile, but that's about it. Good Luck!
Old Sep 13, 2025 | 01:08 PM
user051728's Avatar
user051728
Technically incorrect. All cars are designed and have a 1000 lbs tow rating, in the US legally you can say that its not recommended for towing, but if you look at European specs they will put 1000 lbs or 2000 lbs on all cars that in the US are labelled as "not recommended for towing".
The GTO was a classic example of this, in the US it was labelled no towing, but in Australia it had a 2000 or maybe even a 3000 lb tow rating. To get a 1000 lbs tow rating is frankly not hard, the tongue weight is 100 lbs. Can you put 100 lbs in the cargo area? If so, you can tow. Pulling 1000 lbs is nothing.
Old Sep 13, 2025 | 06:05 PM
BuckySti's Avatar
BuckySti
Enjoy the trip!
I think you meant to say... "Don't use a C8, use a C7 Coupe". I have a C7 Convertible, and not really that more space than a C8, even with making use of the "top space" in the trunk.
Old Sep 14, 2025 | 08:08 PM
Gearhead Jim
St. Jude Donor '13
The 'vert is more fun in some situations, but the coupe trunk holds a lot more.
There's really no bad decision either way.
Old Sep 15, 2025 | 08:53 AM
Family Time
Thx for all the input.I planned to make a rack like one shown in comments.I will make out of aluminum and it will be shorter in height.It will be my winter project as I don’t have hitch in time. I will be ordering hitch when I get back from this trip
Old Oct 3, 2025 | 01:02 PM
edman610's Avatar
edman610
I have the u-haul hitch. Works well. hope you get it sooner. I looked into the Leroy hitch, they had none, and none in the pipeline
Old Oct 3, 2025 | 02:38 PM
user051728's Avatar
user051728
How is that legal?
Old Oct 3, 2025 | 02:51 PM
Family Time
How does it work with license plate? I have not ordered because was coming in after vacation. I am going to ship stuff to different locations we are hitting.We are seeing this weekend how much we can put in with wheelchair.Does plate flip down and cover it when rack is off.Hard to tell in pictures.
Old Oct 7, 2025 | 11:18 PM
batone's Avatar
batone
I just bought one from Uhaul made specifically for the C7.
Trailer Hitch for a 2018 Chevrolet Corvette
  • HitchHitchRate:$292.45Review/Edit Details
    • U-Haul Custom
    • Class 1 hitch
    • Max weight: 1,500 lbs.
    • Manufacturer Part Number: UHI25959
    • Part number: UHI25959
    • Exact Product Specs and Installation Guide - Model UHI25959.
    • Please note:
      U-Haul is the only known company with a hitch that will fit your vehicle. However, these trailer hitches are built as ordered, so please allow 8 weeks to complete the manufacturing process.
    • Watch the installation video
To C7 hitch
