Knocking sound??
Old Sep 25, 2025 | 03:57 PM
Darth VetterC7's Avatar
Darth VetterC7
Cruising
Default Knocking sound??
I’m new to the corvette world just bought a 2019 stingray z51 with 64k miles almost 1 week ago, and as soon as I got home I notice a knocking sound only ever when I shut the engine off, any ideas?
no codes, only the o2 sensor that popped up yesterday
tried to upload video with sound, not sure if it worked, new to these forums
File Type: mov
Old Sep 25, 2025 | 04:18 PM
Macleod52's Avatar
Macleod52
Manual or automatic?
Old Sep 25, 2025 | 04:21 PM
Darth VetterC7
Cruising
Automatic
Old Sep 25, 2025 | 06:06 PM
LS1AB's Avatar
LS1AB
May be the torque tube? Check some videos on you tube for sound bites.
Old Sep 25, 2025 | 06:40 PM
Darth VetterC7
Cruising
just watched a video with the same sound I get and comments said the same thing, I guess there’s really no telling when it could go out it’s my daily hopefully it’s under the warranty
Old Sep 25, 2025 | 08:17 PM
kodpkd's Avatar
kodpkd
Who are you? It helps us, to fill out your profile.
Old Sep 25, 2025 | 09:10 PM
Darth VetterC7
Cruising
im sorry if this comes off wrong, but how does that help? Like I said I’m new to everything corvette and these forums. I want to learn all I can, does filling out profile just generally help others know what car I’m talking about?
Old Sep 25, 2025 | 09:47 PM
Shane1974's Avatar
Shane1974
You are not wrong. Hope you get it figured out.
Old Sep 26, 2025 | 05:41 AM
449er's Avatar
449er
CF Community Team
You need to explain in more detail what you are hearing. Is the noise coming from the engine? Open the hood while the engine is running, do you hear it there? Does the noise seem to be coming from under the car? Can you hear the noise with the engine running & the trans is in gear or in park?
Old Sep 26, 2025 | 06:46 AM
Darth VetterC7
Cruising
I believe it is the torque tube after finding similar noises on YouTube bites, but I did mention in the first post could only hear it when the motor shuts off, I found a few other videos with exact same sound and everyone says torque tube
Old Sep 26, 2025 | 09:19 AM
Macleod52's Avatar
Macleod52
It was a poorly worded post. Essentially he wants you to fill out your profile with all your car details. Year, Trim, Manual/Automatic, etc. It helps everyone who is trying to respond better answer the question because they don't have to ask you a bunch of questions just to be able to better answer your question. Like my question asking if you have an auto or manual. If your profile mentioned what you have I wouldn't have to ask that preceding question. If it were a manual I could have easily answered for you to try turning off the car with the clutch engaged and see if you get the same noise.
Old Sep 26, 2025 | 11:51 AM
Darth VetterC7
Cruising
ahh I see. Thank you for the advice
Old Sep 26, 2025 | 04:55 PM
DoubleG's Avatar
DoubleG
Torque tube.
After you get it repaired, make sure your car never goes into V4 mode again. That's the #1 cause
Old Sep 26, 2025 | 05:32 PM
Darth VetterC7
Cruising
Originally Posted by DoubleG
Torque tube.
How does someone do that without deleting it, that would risk the warranty right? After one week owning and I’m already dealing with this, wouldn’t want to be out more in the future by voiding the warranty
Old Sep 26, 2025 | 05:50 PM
Squeaky Wheel's Avatar
Squeaky Wheel
Very simple. Always drive with the transmission in the manual mode using the paddles, or purchase a Range Device and plug it into your OBD port. Then you can use the normal drive mode of the transmission. Leave it there and forget about it. If concerned about warranty issues, unplug it a few days before taking the car in for service. Problem solved.
Old Sep 26, 2025 | 07:21 PM
DoubleG's Avatar
DoubleG
The third option is to get someone to program the car's computer to never go into that mode. But I have no idea if that affects warranty. The first two are the cheapest and easiest. If you want to "set it and forget it", buy a Range Device or similar and leave it in the OBD like he said. That's the most important mod you can do
Old Sep 26, 2025 | 07:51 PM
Darth VetterC7
Cruising
iv heard discussion about oem tubes vs solid mount, anyone have any tips about that, with just getting this car a week ago I’m very down about already it being in a shop. I know at this point everyone has this issue but I’d rather get more life out of a part then go through this every few years
To Knocking sound??
Old Sep 26, 2025 | 08:48 PM
Laguna Blu's Avatar
Laguna Blu
I drive an M7 and never have I been forced into the 1-4 skip shift, why is that do you think? I'm actually curious.
Old Sep 27, 2025 | 12:31 PM
DoubleG's Avatar
DoubleG
That's probably why someone sold the car. Look at it this way, after getting it fixed you will never have to worry about it again probably. Unlike me who has to wonder if it will happen any day. Mine never goes in to V4, but you never know. And luckily, so many people on here were able to help you with the problem, instead of it being a mystery. Best to get this headache over early, if it's going to happen
Old Sep 27, 2025 | 12:42 PM
Flattman's Avatar
Flattman
Maybe I missed it, but do you have a shop in mind to fix it? Be very selective with your choice and make sure they are well versed in this repair as setting the proper thrust bearing clearance is absolutely critical to get right or it will take out your engine quickly after the repair. Not trying to scare you, just inform you beforehand. Plenty of posts regarding thrust bearing failures resulting from improperly installed torque tubes with automatic transmissions. Knowledge is power
