Help with this noise.
Old Oct 30, 2025 | 04:34 PM
Gman's 14's Avatar
Gman's 14
Default Help with this noise.
I rebuilt my torque tube and then reinstalled the tube back into the transmission and buttoned everything up. When I started the car the transmission makes this noise. I know I showed the tube in this video but the noise isn’t coming from there it’s coming from the transmission. Video attached of the noise. Any advice would be much appreciated.
File Type: mov
Old Oct 30, 2025 | 06:14 PM
BELVIN20's Avatar
BELVIN20
As has been discussed many time on the forum is the exact clearance for the torque tube for the auto trans, I would be concerned about that issue as if the clearance is not correct, it can wipe the thrust bearings in the engine & kill your engine.
Old Nov 1, 2025 | 09:37 AM
Gman's 14's Avatar
Gman's 14
[QUOTE=BELVIN20;1609206249]As has been discussed many time on the forum is the exact clearance for the torque tube for the auto trans, I would be concerned about that issue as if the clearance is not correct, it can wipe the thrust bearings in the engine & kill your engine.[/QUOTE. Would the noise on my video (coming from the transmission) be attributed to the clearance you are speaking of ?
To Help with this noise.
