Corvette c7 possible engine damaged, no idea yet
i have a 2015 corvette z51
Last night i was on the highway and on one of those round/loop exits going maybe 30-40mph when suddenly almost towards the end of it heading into the straight lane i heard what sounded like quick tapping or rattling noise (cant be sure since i had music on and didn't give me time to turn radio off). I thought maybe a wheel issue tapping my fender flares since the car is a bit lower than other c7s. Not even 5 seconds later i noticed i couldnt accelerate, tried switching gears and still nothing so thought it had something to do with the transmission. Had to pull over, the car dead but lit up. Radio, dash everything on but it seemed like engine was shut off. I thought at that moment it just somehow shut off so i tried turning it on and it winded like it normally does to turn on and heard it rev for a second before it shut off and rev again and shut off so naturally i did not try to turn it on again thinking it my engine had a problem. While the quick rev it also made a deep sounding rattling noise. I then checked oil and the dip stick showed nothing, which made me have a mini heart attack cuz wtf. I checked for leaks under the car and on the road behind and nothing, not a drop anywhere. No visible damage or oil stains on the engine from what could be seen in engine bay or under car. Again, i couldnt see much under yet since its low to ground. Oil filter is visible and in place, no signs of damage or oil leak. I did my oil change myself as i always do to all my cars, went to autozone and they confirmed me the oil qrt requirement and even brought it to me to the counter. I cant for the life of me remember if it was 7qrts or 9qrts. Im pretty sure i checked online myself too to make sure beforehand. I even checked dipsticks while cool and even after running for a bit to warm it up, all checked out. I also watched tutorials to make sure i didnt miss any funky steps this specific car may have and did it step by step. Either way, its showing not a drop of oil on the dip stick last night and even this morning that i just checked.
i dont think the engine is seized since it was whining and even tried to turn on a couple times. Does anyone know what it could possibly be?
in addition, it was driving so perfectly. One of the few chilly nights here in FL so i was loving how smoothly it was driving and how responsive it was. No alerts of low oil pressure/lvl which i know the vette gives, temperature was good too, even a little below the regular im assuming due to the weather. I had driven about an hour already before this happened so i can only assume this happened in the last 5 minutes of it stalling. Ive read when cars have no oil they dont drive far at all, so i perhaps it does have oil just its low on it due to an incorrect oil refill? Or perhaps it leaked out during drive and caused this? No idea
ive been told to add some oil and see if it turns on but im afraid of damaging the engine further if it is the issue.
battery, alternator are good. Could it be fuel issue?(its not low on fuel) could it be a sensor not allowing it to turn on? If it is an engine issue, what are your thoughts of what it could be based on it trying to turn on and the rattling?
Popular Reply
2. He has a Z51, so not a wet sump system.
If it were mine I'd drain the oil and see how much comes out and what it looks like, then go from there based on what's found.
9 1/2 quarts is for a z51 with dry sump
If you can recover any of the oil that was in the engine when this event occurred I would definitely get an oil analysis done. The wear metals will tell you what damage may have been done.
Your case might be an oil starvation event due to low oil level or an oil system issue during cornering.
Best case: Oil pressure dropped, ECU shut it down in time with minimal damage.
Worst case: Bearing damage has already occurred, but the engine is still salvageable if you stopped early enough.
Good luck. Hope you have a good outcome.
They tore down my whole engine, and replaced the pump. That was IT. Some of the main journals and crank journals had minor marks on them, nothing other than a surface scratch. The shop said if I planned to add power or modify the engine I should replace but for street driving, they were fine. No damage occurred to any part other of the engine.
Now I didn't lose any oil, so that might make the story moot. But these engines are built like tanks. It might not be as bad as you think. Shockingly engines can (and people do) run them with poor oiling for thousands of miles before they seize or explode.
This just became a bigger problem.
If you checked the oil right after it ran and it didn't show any oil, that's a serious problem on a dry sump. Checking hours later doesn't tell us much on a dry sump as the oil drains back into the reservoir. It will read low if any at all. You should check anywhere from 5 to 10 minutes after you stop the engine. If you check immediately it will likely read a little high (I've never actually done it, I always checked after 5 minutes on GS's and Z06's). Draining it and measuring what's in the engine is a good idea. So is sending it for analysis (that'll take a while).
thank you for your response
Ive been told it could also be the fuel pump or sensors so ill know more once i get home. The worst part is i have no idea of any good trusted mechanics that could work an engine. Almost everyone i know that takes it to one ends up hating the experience.
Thank you for your response
But first do the oil level thing, draining it all and refilling to the correct amount. It should show in your dip stick before trying to start. Don't forget to save some of it to send for testing .
thanks again for your imput
