Corvette c7 possible engine damaged, no idea yet
Sounds like a rebuild to me. There is likely some stuff in the engine that will need to be flushed out. Good luck.
I have not found any sign under the car yet of a leak. The back is clean, only the exhaust tips are a bit black. Where did i find some? Well, in the intake! Ive taken this off before and never found what i found now. A puddle of oil, and most of the intake covered in what looks to be a dried off but oily substance. Oil around the connection to the throttle body. Now, it is not only oil in there, it also had coolant. A mixture of both. See picture i attach, hopefully i can upload successfully. I dont think this is 5-9qrts of oil in there, perhaps it leaked here constantly or its trapped still in the engine
anyways, i have a mechanic coming saturday to work on it with me, and hopefully we not only see what is damaged but also what caused all this. ive read and been told the dry pump tends to damage on this car and causes it to not pump the oil so it gets stuck in the engine and lines, perhaps this was the issue because where the oil went i still dont know. Could it be that it got stuck and blew the engine, spraying it into the intake?? No idea, just me guessing. If these dry pumps tend to damage this way, without alerting of issues prior to the catastrophic failure, should this not be recalled or something? I cant for the life of me believe this is a known issue, that gives no warning, and gm did nothing about it
again to clarify, i did not receive any alerts or red oil pressure light at any moment since the oil change. My check engine light only showed up after it stalled when i tried turning it on.
in addition, i would like to share the error codes showing to me when i put my reader on it Monday night. Please see picture. All this only showing up after it messed up
Errors showing. Intake sensor, throttle body and knock sensor
Oil/coolant inside intake
I mean not sure how it was driven if the engine issues are that bad, unless you just broke a timing chain and the think shot the oil into the intake and all over when it failed. But that would be a pretty catastrophic failure.
That’s normal on these, not an indicator of burning several quarts of oil. If you have oil and coolant in the intake you have major damage.
My brother and i filled it up, I pressed the start button, It again whined up like normal and actually turned on and stayed on….BUT…the noise it was making lets just say wasn’t pretty. Loud knocking or clanking metal to metal type sound and it would have kept going if we hadn't shut it off right then.
Im pretty sure im screwed but does anyone know what it could be? And with wishful thinking could it possibly just need the oil to reach the engine to stop the noise?
Lastly, if it had low oil why the F did it not alert me before it reached an unsafe pressure???
The first thing you need to do now is to remove both drain plugs and drain all of the oil out of the engine (except for the half quart in the filter). When the oil stops dripping, reinstall the two drain plugs and add 8.5 quarts of fresh oil. If the engine is capable of running, start it and run it until the OIL Temp hits 175+ degrees, shut off the engine, wait 5 minutes and check the dipstick. You will have approximately 9 quarts of oil in the engine and should be able to see the oil level at about the center dot on the dipstick. Ten minutes after engine turn off the dipstick reading will no longer be valid due to oil draining out of the dry sump reservoir and the engine has to be run again until oil for a few minutes or until OIL temperature is above 175+ degrees.
When checking oil level in a C7 Dry Sump Engine, always read the OM. Ever since the GM dry sump system was introduced in the 2006 Z06, there have been many mistakes made when checking the oil level and when changing the oil. All have to do with not following the proper method of checking the oil level. If you are idling the engine in your garage it can take 20 to 25 minutes to reach an Oil Temperature of 175 degrees.
Here is a simple diagram that GM attached to the oil fill on C7 dry sump cars. This is mounted on my dry sump system so mechanics working on my car can read it before doing something foolish:
It shows from left to right the engine running, the oil temperature of 175 degrees, the engine not running and the time period when the oil level can be checked.
Bill
No leak?
No smoke?
Installed 7 or 9qts at oil change.
Zero sense unless something in the engine let go and the weak link is the afm lifters.
Bill
sadly i cant turn it on anymore, dont want to damage it further. As soon as its turned on, the loud knocking noise begins.
based off your comment though, lets say the oil did not leak, and it was just a bad reading since we took too long to check the oil after car was shut off(more than the 10 minutes you say) what could have caused the random damage to the engine then? Its all so strange
