Corvette c7 possible engine damaged, no idea yet
Old Jan 2, 2026 | 09:18 PM
  #61
Ronfer97's Avatar
Ronfer97
Originally Posted by 24/Eray
I feel like this is a bad afm lifter (noise and failure) and the checking of the oil level is just completely off.
No leak?
No smoke?
Installed 7 or 9qts at oil change.
Zero sense unless something in the engine let go and the weak link is the afm lifters.
this is what i continue to receive as the problem. Lets see. He canceled on me for tomorrow, so will have to wait another week. Tomorrow though i will finally have time to get under it and confirm everything else myself
Old Jan 2, 2026 | 10:09 PM
  #62
Ronfer97's Avatar
Ronfer97
Hello guys, after extensive searching, im almost sure its rod knock. It acts and sounds almost exactly like the car in this video:
struggles to turn on and pretty much the same sound when on. Perhaps i have damaged rods, lifters, bearings. And from what ive read, rod knock is usually a really bad sign with most replacements being cheaper than a rebuild. I will be doing the repair with a family mechanic, coming with no labor cost but with this rock knock sound, do you guys believe its even worth rebuilding instead of replacing? Based on parts cost vs engine replacement( 5-10k ive seen only)
Old Jan 2, 2026 | 10:17 PM
  #63
Steve_R's Avatar
Steve_R
St. Jude Donor '12 thru '17
I called rod knock in a previous post based on your description. With how little many of these are driven you might be able to find a complete low mileage engine from a wrecked car, which could be easier and cheaper than rebuilding yours, and definitely cheaper than a new one.
Good luck whatever you do.
I’m still curious how it ran out of oil.
Old Jan 2, 2026 | 10:26 PM
  #64
Ronfer97's Avatar
Ronfer97
yeah i just couldnt find a similar sounding video until now. Thanks though for bringing it up. Ive found some engines going for 3-4k with around 20k miles, lets see once i open it
Old Jan 2, 2026 | 11:23 PM
  #65
PicaVette's Avatar
PicaVette
Free labor?
I think the most expensive part to rebuild versus replace, is not the parts $$$, it's the number of (experienced) labor hours required.
Old Jan 3, 2026 | 12:26 AM
  #66
mdolandese's Avatar
mdolandese
Originally Posted by F4Gary
Please keep us informed as to what you find after the tear down.
I second that
Old Jan 3, 2026 | 08:21 AM
  #67
DGA3's Avatar
DGA3
Originally Posted by PicaVette
Free labor?
Good point.
Old Jan 3, 2026 | 11:55 AM
  #68
Ronfer97's Avatar
Ronfer97
Originally Posted by DGA3
Good point.
as its a family mechanic, i wont be charged labor. He insisted on it but of course ill still give him something for the job, i dont like not paying someone for their work. Either way i believe it will be much less than the regular labor cost per hour
Old Jan 3, 2026 | 12:11 PM
  #69
barko1's Avatar
barko1
Time to buy a new crate engine, no oil and lots of noise means no more bearings.
Old Jan 3, 2026 | 12:40 PM
  #70
Gearhead Jim's Avatar
Gearhead Jim
St. Jude Donor '13
At one time, GM used to sell rebuilt engines.
My understanding was that the work was done by an outside company, so it could be good or bad.
Old Jan 4, 2026 | 08:58 AM
  #71
DGA3's Avatar
DGA3
Originally Posted by Ronfer97
as it's a family mechanic, i wont be charged labor. He insisted on it but of course I'll still give him something for the job, i dont like not paying someone for their work. Either way i believe it will be much less than the regular labor cost per hour
That's fantastic!
Maybe some pizza and beer will suffice.
Old Jan 4, 2026 | 11:39 AM
  #72
9sec's Avatar
9sec
stroke it to a 416 billet rods and pistons ditch the dod /aafm and the vvt cam link bar lifters and double btr springs . che trunnion kit in the rockers .080 was 3/8 pushrods and port the heads now you have a reliable lt motor
Old Jan 4, 2026 | 01:40 PM
  #73
Photomania's Avatar
Photomania
Hopefully, you will not have to replace your engine but if you do, there are options. I see crate engines for a C7 for $16,000 and used engines with 32,000 miles for $6,500. One has a 90 day warranty and the other, a 30 day warranty. eBay appears to be the least expensive route.
Many owners pay roughly $2,000 to $4,500 in labor alone at a typical shop for an engine swap/replacement on a C7 Stingray. The cost at a dealership could soar to $6,000.
https://603autosalvage.com/used-engi...lacement-cost/
Old Jan 5, 2026 | 07:24 AM
  #74
DGA3's Avatar
DGA3
Re: the labor cost
Good thing he has a family mechanic!
Old Jan 6, 2026 | 07:43 AM
  #75
barko1's Avatar
barko1
Re: the labor cost
Now that's debatable
Old Jan 11, 2026 | 10:59 AM
  #76
Ronfer97's Avatar
Ronfer97
Hello everyone again, will post some pictures of what we found. We were able to remove the engine yesterday and check it. Still have a bit to open up but so far a piston seems to have been damage, a push rod bent, valve, spring. Coolant found all over, on both cylinder heads but only one seems to have actual damage(driver side). Still some more to inspect but it was too late to continue.
From what my mechanic tells me and what i and my brothers saw, we have two options
1. to replace all pistons, and both cylinder heads along with gaskets, the rods, pretty much every component along with those. That way the engine will run 100% like new basically.
2. replace only whats damaged, so it be the one cylinder head, the one piston and all the components required. Im told if i buy one new piston(if i can even manage to find one individual) the new one will run so well the older ones will be lacking or something like that. But replacing one cylinder head is fine, new one wont affect the other.
Note: i will take both cylinder heads to a shop to inspect and see if repairable. Theres one nearby that specialize on them.
what do you guys recommend? Is replacing the one piston, cylinder head, rod, spring ok? What other things should we look for? What parts must i replace to close it up? Im told theres components that are just one use like some screws, gaskets.
Driver side
Driver side
Driver side cylinder head
Passenger side cylinder head
Spring snapped in half found on driver side
Rod found on driver side
Old Jan 11, 2026 | 12:15 PM
  #77
frankbicknell's Avatar
frankbicknell
f'k I hate when that happens. Looks like engine replacement time.
To Corvette c7 possible engine damaged, no idea yet
Old Jan 11, 2026 | 12:54 PM
  #78
Red Alert's Avatar
Red Alert
So what the hell was the cause??? Any way to tell????
Old Jan 11, 2026 | 01:21 PM
  #79
9sec's Avatar
9sec
if you are only replacing broken parts stick them in and sell the heap. if you plan on keeping the car strip it to a bare bock and start from scratch
Old Jan 11, 2026 | 02:54 PM
  #80
Photomania's Avatar
Photomania
Timing belt broke in my wife’s Nissan years ago. There was interference. Five of the eight valves collided with the pistons of the little four banger. So we had our trusted mechanic replace those five valves. The engine ran so rough that we took it back to the mechanic. There was nothing he could do. So we sold it.
You might want to seriously consider replacing all pistons and valves. But valve guides may be cracked. Piston connecting rods may be bent ever so slightly—enough to cause vibration.
