Ouch
Old Apr 25, 2026 | 03:13 PM
Wmpjr's Avatar
Wmpjr
Originally Posted by ZO6LIFE
You got scammed. There's a recall on this issue. And even having to pay, it should be around $2500-3000 tops. Get a good attorney. Good luck.
out here that is the dealer going price. I have called other dealers and they had the same prices.
if someone has a link to where it says the recall would help a lot. Plus I’m not the original owner.
Old Apr 25, 2026 | 07:31 PM
peterepetepete0@gmai's Avatar
check you vin number at the dealer have the parts guy run a history on it if i remmeber correctly the gm warranty was extened past the original date due to crack in the fuel tank i think it is 8 years and 80k?? but dont fully remeber if your in that range the deler service deptment should have run the vin to see before they gave you the bill
Old Apr 25, 2026 | 08:07 PM
Wmpjr's Avatar
Wmpjr
mine didn’t have a crack in the tank. They said was the fuel pump. But after it happened again and they replaced the fuel controller for free cause it was under warranty. So looks like they did check that. What sucks is it happened after that and they found a bad wire harness to the fuel pump. Now hasn’t happened again. I thank if they did that first I wouldn’t have had any more problems. Thanks.
Old Apr 26, 2026 | 08:23 AM
Tinkertech's Avatar
Tinkertech
Since they could not diagnosis the problem but just throw parts at it, your car was torn apart 2 times.
When you go into such involved repairs, dropping the rear end, you're really rolling the dice.
Russian Roulette isn't my game.
Old Apr 26, 2026 | 09:00 AM
rtv900's Avatar
rtv900
Originally Posted by US332
19 hours @$290 = 5510
my porsche dealer is only 350 and hour and they have an insanely ripoff rate
290 is pretty bad for a chevy dealer
Old Apr 26, 2026 | 01:15 PM
Wmpjr's Avatar
Wmpjr
So you would just let your car sit not operative? I really had no choice if I wanted it running. Have had it a few months afterwards and all seems fine. Knock on wood.
Old Apr 26, 2026 | 01:17 PM
Wmpjr's Avatar
Wmpjr
I agree it is high. Problem is everything here in California is higher than usual. Have a good day.
Old Apr 27, 2026 | 08:44 AM
Tinkertech's Avatar
Tinkertech
Diagnostics were very bad.
A bad wire resulted in dropping the rear end 2 times.
Their moto must be "Fire the parts cannon!".
Also "Pay the nice lady at the end".
I would never go to a parts changer (dealership) for an issue that requires a diagnostician.
But happy to see you got it repaired.
