Ouch
Old Apr 24, 2026 | 08:25 AM
US332's Avatar
US332
Cruising
Default Ouch
Big surprise. 2014 Z51 vert.My 8th corvette. 28,000 miles.
Had an odor of gasoline in my garage when tank was more than half full. No visible leak. No significant difference in gas mileage. Car at dealer now getting replacement of driver side tank. Cost unbelievable. $8000. Mostly labor. Gas tanks should outlast the car but my inquiry asking if GM would like to participate in the cost was firmly denied. Ouch!! Guess it’s still cheaper than buying another car.
Old Apr 24, 2026 | 08:33 AM
GOLD72's Avatar
GOLD72
More likely it is a cracked fuel pump plastic discharge fitting. Common failure with C6 driver side tank pumps. Entire pump has to be replaced with many hours to drop and reinstall the tank. Issue has not been so prevalent with C7 but plastic is plastic which gets brittle with time and temperature.
Old Apr 24, 2026 | 08:35 AM
Macleod52's Avatar
Macleod52
Was this related to the recall?
https://static.nhtsa.gov/odi/tsbs/20...34767-9999.pdf
You can enter your VIN here to see if the recall applied to your vehicle. If it is then you shouldn't have to pay for the recall.
https://experience.gm.com/ownercenter/recalls#/
Old Apr 24, 2026 | 08:56 AM
US332's Avatar
US332
Cruising
Many thanks. Entered the VIN and car was not subject to the recall.
Old Apr 24, 2026 | 09:40 AM
Photomania's Avatar
Photomania
Wow. That would make me not want a Corvette anymore. (And then I would come to my senses the next day.)
I had a brand new Firebird many years ago and there was a microscopic hole in the tank. Only a vapor smell at first, Then a slow leak. A patch kit from an auto parts store did not help. Car was under warranty but GM would not replace the tank. Threatened to use my position as a staff writer on a daily newspaper. GM then replaced the tank. Seriously doubt that would work now.
As for your case, I have heard that is a 10 to 20 hour labor output. I would ask exactly where the leak is located. Some leaks can be sealed up without dropping the tank. Maybe take the cheap route and trade the car for a 2018, which is less prone to this issue.
With the help of a relative, I dropped the heavy tank on a Dodge Caravan so I could replace the fuel pump. I am not a mechanic and that took about two hours in a driveway. That was fairly straight forward and simple. Nothing like a C7.
Old Apr 24, 2026 | 10:49 AM
RonC7's Avatar
RonC7
The recall in Post #3 is for the anti-siphon grid being out of place. The filler pipe gets replaced. There is no vapor or liquid leak. This recall was done on my 2014 in a few hours.
The fuel pump / tank flange leak is on this special coverage:
https://www.corvetteactioncenter.com...ange-1399.html
Good for 10 yr / 120K miles. Your 2014 has likely "aged out" of the coverage...
GL
Ron
Old Apr 24, 2026 | 10:56 AM
Wow, that is one heck of a cost for the repair. Good luck getting the car fixed.
Old Apr 24, 2026 | 11:00 AM
Macleod52's Avatar
Macleod52
Can you give us a breakdown of the parts/labor cost? That seems insanely high. Being generous that parts were $2000 and $6000 was labor that means they charged you 30hrs of labor assuming a $200/hr rate.
Old Apr 24, 2026 | 12:01 PM
US332's Avatar
US332
Cruising
19 hours @$290 = 5510
tank 1712
rear alignment. 200
taxes and fees the balance
breathtaking for sure
Old Apr 24, 2026 | 12:14 PM
Vader_C5's Avatar
Vader_C5
2023 C5 of the Year Winner - Unmodified
St. Jude Donor '25
Good luck, make sure you are enrolled in GM Rewards to get some points back at least...
Old Apr 24, 2026 | 01:24 PM
Photomania's Avatar
Photomania
tank 1712
rear alignment. 200
That is extremely high for labor. I would check with another Chevy dealership. I have had independent shops with lots of Corvette experience work on my Corvettes that were out of warranty. An independent shop will not charge $290 an hour.
Old Apr 24, 2026 | 01:58 PM
US332's Avatar
US332
Cruising
Agree. My local corvette specialist ($165 per hour) suggested a dealership due to difficulty with the repair including sourcing the parts. He turned down the job. I took their advice and was kinda of trapped with the car on the rack and tank partially exposed. Zero negotiating power. Hopefully they will do superior job with repair.
Old Apr 24, 2026 | 02:55 PM
mdolandese's Avatar
mdolandese
Wow that’s awfully expensive! Hopefully they do a professional job and you’re back on the road shortly. Good luck
Old Apr 24, 2026 | 04:44 PM
TraceZ's Avatar
TraceZ
My car had this issue - was not in the recall list. A dealership in town here made a call and got it covered, fixed it at no cost to me.
By the book this repair requires removing the entire drivetrain and rear cradle.
I researched another way - by instead removing the rear facia and some exhaust parts it is possible to detach the fuel crossover pipe allowing the tank to drop out without dropping the entire drivetrain.
The mechanic needs long thin arms to do this, but it saves a TON of time and gives you piece of mind that they didn't screw up the torque tube end play.
The dealership had no issues doing it my way.
Old Apr 24, 2026 | 06:38 PM
Wmpjr's Avatar
Wmpjr
tank 1712
rear alignment. 200
very close to what I was charged to replace the fuel pump on my 2019 stingray. $6,000.00 for that. Apprx $ 300.00 an hour. Couple hundred for pump.
Old Apr 24, 2026 | 08:22 PM
v26278's Avatar
v26278
$290 an hour? Holy **** that’s high
GM has a warranty for this issue but it is only valid for ten years from the cars in-service date.
Old Apr 24, 2026 | 08:28 PM
Photomania's Avatar
Photomania
Typical fuel pump replacement costs:
Ferrari - $1,200 - $3,000
Lamborghini - $1,500 - $3,500
McLaren - $1,500 - $4,000
Mustang GT500 $1,300 -$1,600
https://www.kbb.com/mclaren/fuel-pump-replacement/
https://repairpal.com/estimator/ford...ce=chatgpt.com
To Ouch
Old Apr 24, 2026 | 10:13 PM
Wmpjr's Avatar
Wmpjr
Well. That makes me feel better. Haha. Good ole gm.
Old Apr 25, 2026 | 03:35 AM
449er's Avatar
449er
CF Community Team
$290. per hour....yikes!
Old Apr 25, 2026 | 05:54 AM
ZO6LIFE's Avatar
ZO6LIFE
You got scammed. There's a recall on this issue. And even having to pay, it should be around $2500-3000 tops. Get a good attorney. Good luck.
