C7 Tires
He knows I drive my vettes a good bit, and yes through the winter on nice days, but there are days I drive the car below freezing for certain and am I to understand GM put a tire on this car that can't be driven in freezing temps???
Not quite certain, but I believe that would be a first.
Thanks in advance for any feedback.
Other than that..love the new ride.
As long as its not deep snow and you drive with common sense..(meaning carefully) you can drive these cars all winter all.
I've been doing just that for 5 years on my C6 Z51 with stock runflats or hankook evos....
If your really concerned then buy a set of take offs and snow tires or winter all season tires..
Ive been driving rwd cars since the 70's and realize the importance of taking it slower in inclement and colder weather..
Near zero and the rubber does get harder etc...but like I said...just common sense and you'll be good..
Anyway, if you have PTM use it with your outstanding street tires!
I'm certain the newer summer tires perform best in the warmer summer months and not as good in colder temperatures, but certainly acceptable in all but icy road conditions. I would also bet the dealer's advice not to drive in very cold temperatures isn't in the owner's manual.
Ref. number:Service / Service Operations / G_0000157402
Subject:ZL1 - 1LE Tires
GM CUSTOMER CARE & AFTERSALES
GMSO415
URGENT - DISTRIBUTE IMMEDIATELY
Date: January 25, 2013
SubjectZL1 - 1LE Tires
Models:Camaro ZL1 And 1LE
To:All Chevrolet Dealers
Attention:Service Manager, Sales Manager, Warranty Administrator, Parts Managers
The Camaro ZL1 and 1LE vehicles come standard equipped with 285/35ZR20 & 305/35ZR20 Goodyear F1 Supercar G2 D.O.T. approved ultra high performance summer tires with track capability.
Goodyear F1 Supercar Performance tires are a summer season tire and are not intended to be driven on snow, ice, or road surfaces below -7° C (20° F).
If the ambient temperature in your location is at or below -7° C (20° F), DO NOT MOVE THIS VEHICLE. The rubber used in these tires loses flexibility and may develop surface cracks in the tire tread/shoulder area at colder temperatures. Tire movement, when the temperature is below -7° C (20° F), may result in surface crack in the tread area of the tire. A surface crack on a tire is cosmetic and will not result in a loss of air
Example of a tire with a surface crack.
Special tread and compound used on these performance tires will cause a decrease in performance in cold climates, heavy rain, and standing water.
Driving on wet roads, in heavy rain, or through standing water with Summer Season Performance tires may result in hydroplaning and loss of vehicle control.
Driving with Summer Season Performance Tires on snow, ice, or cold road surfaces can cause loss of control or an accident
Refer to service bulletin 04-03-10-013G: Driving Characteristics of Rear Wheel Drive Vehicles and Available Winter Tires for further information on available winter tires.
Tire Storage
It is recommended for these tires to be stored indoors at temperatures above 20 deg F (-7 deg C) when not in use. If the tires have been subject to 20 deg F (-7 deg C) or less, let them warm up in a heated space to at least 40 deg F for 24 hours or more before installation or driving the vehicle. Inflate the tires only after they have been warmed above 40 deg F (5 deg C). Do not place tires near heaters or heating devices used to warm the room where the tires are stored. Do not apply heat or blow heated air directly on the tires. Always inspect tires before use after storage periods.
Michael
Its a tire compound issue, not a vette issue. If you want great handling and or max performance before a track tire, you get summer tires. If you want to drive it in under 40F you get winter performance tires. All seasons tire do a little bit of everything, but nothing well.
I would highly recommend it.
