First Short Shifter Installed!
Oct 24, 2013 | 12:41 AM
Houston Events Coordinator
St. Jude Donor '11-'12, '14
I believe in the Beer Fairy
Quote:
Originally Posted by
wjnjr
Love the look!
Looks like Chris is first to market with a C7 shifter. Nice job!
but, the **** is getting a little busy now...
We can make any **** to go with it.
Oct 24, 2013 | 12:22 PM
So how is it driving the 7 speed? Any chance of getting 7th when you want 5th upshifting from 4th, or getting 4th when you want 6th downshifting from 7th?
That's a lot of gears on one stick, maybe it should have had a splitter like a truck.
Oh wait, they did that already on the early C4s...
Oct 24, 2013 | 12:34 PM
wjnjr
I can honestly say that I usually go from 5th straight to 7th. I figure If I'm going fast enough to be in 5th then why not go to 7th for the lower RPM's.
Oct 24, 2013 | 12:35 PM
We have the short throw shifters up on the website now. The one that works with stock is available asap! The Hurst style is a 3/4 week wait.
Starting at $159
http://forums.corvetteforum.com/c7-v...-shifters.html
Mar 4, 2014 | 12:56 AM
Where can I get one of those pistol grip shift handles?
Thanks,
Mar 4, 2014 | 07:32 AM
Caholo1
Thanks,
About a week after placing order
Mar 4, 2014 | 04:01 PM
Andrew6
Where?
Not when.
Mar 4, 2014 | 04:25 PM
Caholo1
Where?
Not when.
I'm in Houston, but you can order frim thedoubleaa.com
Mar 4, 2014 | 07:59 PM
TEXHAWK0
I have this shifter in my C5, and it will also fit C6s.
The base is not a Hurst part, but a custom base from Core-shifters. The shifter mechanism is from the Hurst Billet plus 2 shifter design. The chrome stick and ball are stock Hurst parts. The stick bolts to the stub on the base..
It does not have shifter stops, but neither does the stock shifter since they are built into the transmission. The throw is the same as the Hurst short throw shifter and the C6 stock shifter, so you do not gain anything as far as reduction in throw...
I use the Hurst Billet Plus it is about 30 percent or so shorter.
No point in putting a shifter unless it shortens the throw!
Mar 4, 2014 | 08:40 PM
Look forward to getting mine put on Friday...
Mar 5, 2014 | 10:14 AM
02txceta
should be nice, I haven't seen what the black ball looks like so going to have to get lots of pictures of it!
Mar 5, 2014 | 04:10 PM
Since car is all black inside, I thought would look good...
Mar 6, 2014 | 09:00 PM
Like this!! I like it!!
The only down side to it is, that the transmission noise comes through the shifter.
I would post the seller, but I was threatened on here before for just asking if a seller's prices were right on their web site. Just do a google.
Mar 7, 2014 | 12:47 AM
jb306y
We sell those as well
Mar 7, 2014 | 03:44 PM
I've been black-balled...lol. Looks great! Thanks Andrew
Mar 7, 2014 | 11:09 PM
Came out awesome. Just got home from the shop I'll post pictures later
Mar 9, 2014 | 08:36 PM
jb306y
Mounted correctly! whisper quiet like stock!
Mar 10, 2014 | 05:58 PM
I tried to open your video, but couldn't.
My factory 7 speed manual shifter **** is slightly crooked, and I just want to straighten it.
Can you tell me again how to remove the factory **** so I could adjust it?
Many thanks
Mar 10, 2014 | 06:05 PM
Houston Z33
How do you remove the factory shifter ****? My is crooked and I just want to straighten it out.
Many thanks
Mar 10, 2014 | 11:18 PM
ahesq
Many thanks
Define crooked. Its held by the chrome ring then screwed into the shaft
