MSRC Questions - Can't get into PTM menu
Guys -
Just took delivery of my new C7 Z51 with MSRC but for some reason I can't get into the PTM menu. Can someone confirm if I am doing this correctly:
1) Put the car into Track mode with the drive mode selector
2) Car is not moving (tried with park brake on and with off)
3) press the driver mode selector twice quickly (tried all kinds of speeds)
Either nothing illuminates or I just get the TC Off icon showing up. I never get the PTM menu like you see on youtube and the review videos.
I can hold the TC off button for the long-press to get what the manual describes as competitive mode (TC Off and The Traction light on) - Should this even be possible with the Z51 MSRC or does PTM completely replace this function?
Is there a way to verify that the MSRC option is installed on the car? Sticker shows the option correctly but can you verify it on the car somehow?
Thanks!
Thanks!
I would advise opening the glove box and reading over the procedures in the owners manual.
I'll have to go look and see if there is a paper manual in the car
I read the direction in the PDF from the GM site linked on the forums here: forums.corvetteforum.com/c7-general-discussion/3329844-owners-manual-its-up.html
And also watched the video on he system here:
PTM not working.
I am having the same problem. Followed owners manual and video. Dealer cannot get it to go into this mode either. Is the auto tranmission a factor? Does it work only on Manual transmission?
I am going to try and pull the battery cables tonight and do a hard reset to see if it helps if I have the time.
Hmmm. I'm not a C7 owner, but have read on this forum of the tach showing redline at 3500 RPM during break-in first 500 mi. Is it possible that you can't access the PTM mode until break-in is complete? Just a thought...
Also an update on my battery pull last night. It is a real PITA to make happen the way it is mounted in the back of the trunk but I managed to disconnect it for almost an hour. When reconnected the car had lost all of it's memory and presets but I am still unable to access the PTM menu.
This was how I got into the other mode but I never saw the PTM menu where I could select between Wet, Dry, Sport, and Race modes.
Can you confirm that you and I are talking about the same PTM menu?
Thanks!
The missing link to the procedure is that you must press the brake pedal and then press the driver mode selector twice quickly. Works every time and fixed the problem.
Brake pedal wasn't necessary on mine I made the adjustment while driving down the road. Seems it works on some and not others.
Track mode on dial. Two clicks on center button pulls up menu scroll right for PTM settings.
I too can do it while driving. I tried it again yesterday and it worked fine. Make sure you're in track mode. Press the center button twice, but on the second push I held it down a bit longer. That seemed to get it into track mode every time. Once in PTM you can use the dial to select the mode (you'll see the selections at the bottom of the display).
I tried to use this but couldn't get it to work either. I can select the mods easy enough rotating the dial, but once in track mode couldn't get into any other options. I'll try it again later today.
