Squealing brakes
Old Oct 7, 2013 | 11:46 PM
jconyers1's Avatar
jconyers1
Default Squealing brakes
Anyone having issues with squealing brakes on their C7 Z51? If so, what did you do to fix the problem? Thanks...
Old Oct 8, 2013 | 12:52 AM
dvandentop's Avatar
dvandentop
burnish the brakes per manual
Old Oct 8, 2013 | 09:43 AM
travisnd's Avatar
travisnd
Use them harder and get the pads properly bedded.
Old Oct 9, 2013 | 08:09 AM
JRitt@essex's Avatar
JRitt@essex
Supporting Vendor
Here is a video I put together a while back on How to Bed-in Pads and Rotors. Check it out.
Old Oct 9, 2013 | 08:46 AM
erikszr1's Avatar
erikszr1
even after the break in procedure they still may be noisey. like the c6 zo6 pads they like to be excercised. light, slow driving will make them noisier than ever.
Old Oct 9, 2013 | 03:03 PM
Hot Rod Todd's Avatar
Hot Rod Todd
The dealer showed my a bulliten from GM that clamed the performance oriented brakes on the C7 will always put out lots of dust, and may be noisy. At some point you'll most likely be able to change to a different pad that will reduce the noise, but may also be lower performance.
Old Oct 11, 2013 | 06:33 PM
jconyers1's Avatar
jconyers1
Finally got a chance to burnish my brakes yesterday. I followed the manual to the letter. Looks like it may work after all...
Old Oct 12, 2013 | 10:24 AM
Bill Dearborn's Avatar
Bill Dearborn
High performance brakes require some sacrifices. Noise is one of them. I never let it bother me. Only the people not in the know are bothered by the squealing.
Bill
To Squealing brakes
