Brakes
Old Oct 8, 2013 | 02:17 PM
Carbotech Adam's Avatar
Carbotech Adam
Supporting Vendor
St. Jude Donor '11,'13
Default Brakes
Who can tell me if the Z51 car and Base car have the same caliper in front? Also, willing to make a free set of pads for anyone willing to ship us a front and rear pad from a Z51 and a base car. call me at 216-780-8825 if interested.
__________________
Adam Adelstein
Email: adam@ctbrakes.com
Web: Carbotech – CT Brakes
Old Oct 8, 2013 | 03:12 PM
zipcode's Avatar
zipcode
they have the same caliper in front
Old Oct 8, 2013 | 03:24 PM
Carbotech Adam
Supporting Vendor
That's what I thought but, we our being told 2 different pad shapes
Old Oct 8, 2013 | 03:34 PM
C7pimp's Avatar
C7pimp
So, I'm guessing a Z51 rotor will fit a non Z51 car if you also change the pad. Good news, I like the Z51 brakes, it's the only thing I really cared about from the Z51 package. That's a cheap upgrade!
Old Oct 8, 2013 | 03:35 PM
C7pimp's Avatar
C7pimp
Naturally, since the Z51 rotor is significantly larger, to take advantage of the increased surface area, you'd have a different pad.
Old Oct 8, 2013 | 04:15 PM
Carbotech Adam
Supporting Vendor
Wasn't the z51 rotor bigger on the c6 and 5 they take the same pad.
Old Oct 10, 2013 | 03:47 AM
Trackaholic's Avatar
Trackaholic
If the two versions use the same caliper, how would you have two different pads? I suspect the area may be the same between the two, but the Z51 mounts the caliper at a larger radius, to account for the larger diameter brake.
I could see there being two versions of pad due to material differences (Z51 maybe being a higher temp pad), but I would expect the size to be the same. Actually, if the two rotors are also different thicknesses, perhaps the pads could vary in that respect as well?
That's just a guess of course.
-T
To Brakes
