After working hard the past few months we are proud to bring you guys THE FIRST C7 Heads/Cam package. We are installing A set today on our shop car and should have results soon!
C7 Heads/Cam Parts Package:
LMR Proprietary CNC ported Cylinder Heads
LMR Custom Grind Camshaft with VVT/AFM
Chromoly Pushrods
LMR custom phaser limiting kit
Head Bolts
Head Gaskets
Water Pump Gaskets
Front Cover Seal
Crank Bolt
Price for this setup (Parts only) is $3599.58 Plus shipping to your door. If you send us your stock cylinder heads you will be refunded $500 when we receive them. Can ship them to us first and we can port yours (7-10 business day turn around time) and save that $500 up front if you'd like for a grand total of $3099.58 plus shipping.
__________________
Worlds Quickest C8 Corvette 8.83@160MPH
FIRST C7 Corvette in the 7's & 9's
2019 ZR1 LT5 8.874 @ 155
Current C7 World Record Holder 7.55 @ 184 MPH
Quickest and Fastest GEN5 LT Powered Vehicle
LMR1200HP Supercharged C7 8.84 @ 160
LMR1200HP Twin Turbo C7 9.35@155mph-2014
2 TIME OUTLAW DRAG RADIAL LSX CHAMPION 2008/2010
9.47 ZR1 Corvette-2009 LATE MODEL RACECRAFT
713-466-9900
LateModelRacecraft.com
Too many PMs, please call or email instead, thanks!
Oh man, can´t wait for the dyno!
It's just unreal how quickly mods for this car are coming out.
Are you going to test the package with stock exhaust, or headers?
I heard someone mention heads had to be pulled for a cam change in the LT4....is that correct or misinformation?
I would say misinformation but they can chime in for sure. Some people don't like the AFM lifters so they say you need to swap the lifters out to do a cam, but if you have a well designed AFM cam like LMR and others are going to use, then the stock lifters should work just fine.
So you've never tested them on a live engine and they're already for sale?
We will be testing SEVERAL different cam designs with our different stage cylinder heads to get real world results to come up with the best combinations. We have several different types of customers that want two completely different results when it comes to heads/cam packages. We also have to test our systems so we know which setup to recommend to each individual customer. For more information or questions please email
We are going to test Heads/Cam with STOCK AIR box and STOCK manifolds/exhaust. Then install Longtube headers to test even more results......
