C7 at RPR 11.4
Old Oct 26, 2013 | 05:33 PM
peter pan's Avatar
peter pan
Life Time NCM #2196
Flat out awesome, school me on flashing the converter? Got an A6 09 with just a tune and cane only get 2 or so on 60'.
Old Oct 26, 2013 | 07:36 PM
GTJim's Avatar
GTJim
Very impressive! Looks like the A6 is the way to go. Can't wait to see what a C7 will do with a CAI, Pfadt headers, and a tune!
Old Oct 26, 2013 | 10:39 PM
DRLC5's Avatar
DRLC5
What gear did you cross the line in?
Old Oct 26, 2013 | 10:46 PM
RussBt's Avatar
RussBt
From: Admit Nothing, Deny Everything, Make Counter Accusations.
Originally Posted by racerns
1.68 is very impressive on stock tires.
Was that car on the stock tires?
Old Oct 27, 2013 | 11:04 AM
racerns's Avatar
racerns
Originally Posted by Snorman
To keep things in perspective regarding that ZR1 pass...
Dec 18 2011 at MIR in Budds Creek Md, the weather was great for making the power as drag times says the DA was -1449
S.
You left out the rest of the story.
...the problem was the traction on the stock tires was limited because it was very cloudy all day and track temp was lower than we like to have for maximum traction, especially with stock tires. That being said, I did get a couple passes where it hooked up on a good fast throttle squeeze.
I was there running that day too and the trap speeds were not any better than on days when the DA was in the +500ft range. I had a hard time with traction. Kyle was able to put together a really good launch and run despite the conditions.
I have no doubt that a C7 auto is going to be much easier and consistent to launch and get low 60' times than a ZR1 but the ZR1 has run numerous low 1.7X (and a few 1.68s) 60' times, stock, so comparisons should be to drag strip times not factory specs.
Old Oct 27, 2013 | 11:14 AM
sardeanie's Avatar
sardeanie
Cruising
I posed the question if the Z51 was instrumental in Snorman good traction, but seeing this base car click off 1.6x 60ft I would guess "no". So for the straight line guys the base car A6 may actually be a good starting point. I prefer the "spoiler delete" look as well.
Interesting results coming in. Thanks all!
Old Oct 27, 2013 | 11:19 AM
Mike Campbell's Avatar
Mike Campbell
What I like about this run is that it's a base non-Z51 car and that in my opinion letting the A6 do the work I believe you would have picked up .05 secs. Plus when you get a little more time to try flashing the trans like Snorman did. You might pick up a little better 60' times. Overall very very impressive and not a run at one of the "Majic" tracks.
Old Oct 27, 2013 | 11:20 AM
Snorman's Avatar
Snorman
Scraping the splitter.
St. Jude Donor '13-'14-'15
I have done a LOT of drag racing over the last 10-12 years. Probably somewhere around 100-120 passes in the last year alone.
There is no possible way I will believe that a ~2000' difference in DA will have no effect on trap speed because of traction. If the car doesn't hook on the front half then the run is wasted anyway, and even with as much power as ZR1's make, they aren't going to be traction limited on the back half. There is probably a reason those top two passes are 3+ mph faster than your own, even with similar 60'. It's the DA.
I am not really sure why the ZR1 was even brought into this discussion.
S.
Old Oct 27, 2013 | 11:24 AM
Snorman's Avatar
Snorman
I agree entirely that a base 1LT A6 car will be the hot ticket for the drag strip.
S.
Old Oct 27, 2013 | 11:48 AM
racerns's Avatar
racerns
S.
I was only responding to a comment by someone making a comparison with the ZR1.
I too have done a fair bit drag racing over the part 5 years (+100 passes)and most of it has been with other ZR1s at the track. I have seen them run 132mph in positive DA weather. If you listen to the video of Kyle's run you can hear him spin on the 1-2 and the 2-3 shift. You don't think that will hurt trap speed? As for my trap speed compared to the others (Kyle, Jamie, and Ranger), I have been at the track with them the same day and they always trap +2 mph more than me, even driving my car. That is because they are much better at shifting than I am. The one thing I figured out was the launch which kept my ETs in their range even with a lower trap.
This is nothing against the C7 as I think it performing fantastic at the dragstrip like I predicted.
Old Oct 27, 2013 | 12:02 PM
Snorman's Avatar
Snorman
That car barked the tires on a well-prepped track. I doubt he lost much, if any, momentum or trap speed on that pass.
Back to C7's...
S.
Old Oct 27, 2013 | 12:03 PM
Snorman's Avatar
Snorman
That was what I found most interesting...the car seemed to like some rpm on the launch. As I said in another post, it may be a function of the tune.
S.
Old Oct 27, 2013 | 01:30 PM
  #33
DRLC5's Avatar
DRLC5
Whats the story on this C7?
Old Oct 27, 2013 | 03:47 PM
  #34
dcbingaman's Avatar
dcbingaman
OK, one dude puts the car in D and let's the tranny shift itself and gets a 11.67 quarter mile time. The second dude puts the car in M and paddle shifts and gets a 11.47 quarter mile..with a tune.
When are certain people gonna stop flapping their gums about how slow and crappy this A6 6L80 transmission is ? It is not the same programming as the A6 in the older C6's, and it appears, to me anyway, to work as well as the vaunted 8-speed ZF, and damn near as well as a DCT. These times prove it - especially the paddle shift time. Way to go guys !!
It think it may well be possible to get into the high tens with a tune, cam and Kooks headers, and an A6. Stay tuned....the next 12 months will be fun to watch.
Old Oct 27, 2013 | 04:49 PM
  #35
peter pan's Avatar
peter pan
Life Time NCM #2196
School me on just flashing the converter prior to launch, I would like to give this a try soon in my C6 A6 with just a cold air intake and tune
Old Oct 27, 2013 | 08:24 PM
  #36
Mike Campbell
Snorman:That was what I found most interesting...the car seemed to like some rpm on the launch. As I said in another post, it may be a function of the tune.
You may be right, but in my opinion I think it's really the difference between the electric diff & the standard. I believe there's a subtle difference in the launch software. The C6's responded to some RPM on the launch. My C6 ran best with 1200 RPM at launch. Just maybe the eLRD responds differently. What do you guys think ?
Old Oct 27, 2013 | 08:36 PM
  #37
Snorman's Avatar
Snorman
I don't think it has anything to do with the diff. My car just felt flat in the first ~60-80', and the drop of ~.05 in the 60' proved that.
I'll try to play around with it a little more next Monday at the next rental.
S.
To C7 at RPR 11.4
Old Oct 27, 2013 | 10:19 PM
  #38
StreetGame101's Avatar
StreetGame101
Thanks. The car really does feel a lot better than the c6's. I've owned two a6 c6's (bought brand new) and drove plenty others. The 07 was a mid. 10 sec car and the 08 went 9.8's on the stock transmissions. So I'm very fimiliar with the a6. The a6's in the c7's are in a whole other league when the two are compared. I would really like to push the limit to one of these transmissions.
Tommy
Old Oct 28, 2013 | 11:40 AM
  #39
StreetGame101
3rd gear.
Yes they were. First run was with the factory 32lbs of air. For this run I dropped it down to 27lbs. I believe the suspension on these c7's are something else.
Old Oct 28, 2013 | 12:18 PM
  #40
slief's Avatar
slief
Originally Posted by TTRotary
Another ridiculously fast one. These cars are turning out to be monsters. Waiting to see the first headers+tune+A6.
Funny but true. Not 6 months ago, this forum was a train wreck with people up in arms about the lack of power and skinny tires. Forget the rear end. Now all those cynics are gone as their arguments have been proven invalid. It's especially nice to see both stock and tuned cars getting better performance numbers than those that GM posted.
The C7 is proving to be everything GM said it would be and more. I can only imagine with the future will bring with the Z performance versions. This car has some seriously scary potential!
