Recall for Diff.
Old Dec 15, 2013 | 12:09 PM
  #41
vegasredz062's Avatar
vegasredz062
St. Jude Donor '08
Originally Posted by redplasticcar
Mine is #2894 in shop getting new diff now. Also not a z/51 base cars have this problem too. Also the diff noise started in less than 400 miles.
I found out my build is actually 7455 , 2490 number was dealer stock.
I hope they figured it out by 7400 lol
Old Dec 15, 2013 | 08:14 PM
  #42
Cruncher's Avatar
Cruncher
Originally Posted by midnightbluS10
I was paid more than enough for each PDI that I did. There was an extensive list, which I happily went over on each and every car that I PDI'd. Which included all fluids.
If any Corvette left with low fluid, and its actually checkable, then someone didn't do their job...multiple times at multiple locations. And I wouldn't doubt it. PDIs are seen as gravy work, and done asap with as little effort as possible, I'm sure. Also considered by some to be a waste of time and money, when they could be making $ on a better job with more bookable hours. So they whiz thru it, giving it the penci check only.
I agree with you. Once I purchased a Jaguar XK-E. The "checklist" was in the glove compartment. Before I got out of the parking lot, I found that that stereo was "stuck"--it wouldn't change channels & the differential whined really loud. I had to wait for a new stereo and a new differential. The dealer should of told me to buy two Jaguars; one for driving and one for in the shop.
Old Dec 18, 2013 | 04:39 PM
  #43
djseto's Avatar
djseto
Took my non Z51 in for this recall. thankfully I was good on fluid, but just wanted to confirm it's for non Z51 vehicles as well.
Old Dec 18, 2013 | 09:52 PM
  #44
redplasticcar's Avatar
redplasticcar
Got my car back today all seems good no noise.
Old Dec 19, 2013 | 10:03 AM
  #45
garwood94's Avatar
garwood94
Default Z51 eDiff Noise
I have number 1040 and it pops and bumps significantly while moving around parking lots at slow speeds and turning sharply. I just assumed this was the new normal - but am I hearing that this should not be happening? I will be checking the fluid this afternoon as I have less than 600 miles on the car...
Old Dec 19, 2013 | 11:12 AM
  #46
USAF's Avatar
USAF
Shame on you all.
Nobody has put up a youtube video of how to check it yourself.
Slackers
USAF
Old Dec 21, 2013 | 10:30 PM
  #47
davetx's Avatar
davetx
Originally Posted by USAF
Shame on you all.
Slackers
USAF
My Z51 Vert was just checked by dealer serial #7093 3/4 quart low
Old Dec 22, 2013 | 12:33 AM
  #48
Late Model Racecraft's Avatar
Supporting Vendor
Originally Posted by Anthony @ LGMotorsports
I don't know if anyone else has seen this but talking to the local dealer there is a possible recall on at least the Z51 cars due to a possible lack of correct fluid level in the diff's.
Could be up to a quart low.
I don't know if this effects all of them or just the Z51 cars but if you have one, check your diff fluid.
Each one we have worked on we have had to add fluid. Definitely an issue.
__________________
Worlds Quickest C8 Corvette 8.83@160MPH
FIRST C7 Corvette in the 7's & 9's
2019 ZR1 LT5 8.874 @ 155
Current C7 World Record Holder 7.55 @ 184 MPH
Quickest and Fastest GEN5 LT Powered Vehicle
LMR1200HP Supercharged C7 8.84 @ 160
LMR1200HP Twin Turbo C7 9.35@155mph-2014
2 TIME OUTLAW DRAG RADIAL LSX CHAMPION 2008/2010
9.47 ZR1 Corvette-2009
LATE MODEL RACECRAFT
713-466-9900
LateModelRacecraft.com
Too many PMs, please call or email instead, thanks!
Old Dec 22, 2013 | 01:13 AM
  #49
xp800's Avatar
xp800
That's normal. It's front tire chatter, not the diff. There are a bunch of threads on it in the General section. It's talked about in the manual too.
Here are only a couple:
http://forums.corvetteforum.com/c7-g...is-turned.html
http://forums.corvetteforum.com/c7-g...-tire-rub.html
Old Dec 22, 2013 | 10:03 AM
  #50
BERETTA's Avatar
BERETTA
I picked up my Z51 on 12/19/13 number 7035. I asked the dealer if they checked the differential fluid level and he said oh yes we check everything thoroughly. Well it must have had them worried because when they were cleaning it up they put it back on the rack, I went back and talked to the tech he said it was full and didn't have to add any. I am not sure if they have released a vin break point on this issue? I am glad they checked for piece of mind because I was 457 miles from my house.
Old Dec 24, 2013 | 08:37 PM
  #51
SilversledC7's Avatar
SilversledC7
This issue reminds me of the CTS-V. Most of them were under filled from the factory. The diff in my CTS-V wagon made the worst whining sound at 8800miles and had to be replaced.
Is GM sourcing their diffs from a dollar store or something?
Old Dec 30, 2013 | 02:28 AM
  #52
2006c6keller's Avatar
2006c6keller
Default Slow learner!
This is quite interesting on differentials. Not trying to hijack the thread, but GM has been having rear end problems for over 50 years per comments of others in previous threads. My 06 C6 is on its third (3rd) differential. It seems that GM is a "slow learner" about differentials since this has been going on for over 50 years per others! Others have commented that this problem was also on other GM car models.
Old Dec 30, 2013 | 12:39 PM
  #53
1Bridog's Avatar
1Bridog
Default Diff FLuid
Hi all... FYI
My vin is 3872 and I was told my car was affected and brought to dealer for "checking". Did the reflash at the same time. I was told cars built prior to 11/17 ( guessing from memory) need to check
Hope that helps! Thanks everyone for sharing, it has helped me immensely as a new first-Corvette owner
Originally Posted by Gr8ful
I call the local dealer and he ask for my VIN. He checked and said mine ( 3385 ) was not effected in the recall and that it is by vin only and no need to have the fluid level checked.
Still, I would feel better if it was checked. I need a shop manual so I can do this stuff myself.
Last edited by 1Bridog; Dec 30, 2013 at 03:15 PM. Reason: adding info...just got done. They added 1 quart to the differential and flash upgrade to the software. all good
Old Dec 30, 2013 | 01:42 PM
  #54
killascrimp's Avatar
killascrimp
my car was low on fluid, a few times when i pulled in the garage, i noticed a burning smell but i thought it was normal, i hope my diff is ok. my vin is 1077 ,
Old Dec 30, 2013 | 02:31 PM
  #55
chaase's Avatar
chaase
St. Jude Donor '12
Originally Posted by Z06pete
Back in the day I use to be a Factory Trained Corvette Tech, And one of my jobs was to PDI all of the new just delivered Corvettes hot off the truck. And if the car was Ordered or sold it didn't leave the dealership until all fluid levels were checked and topped off even the windshield washer fluid.
I can't believe for a minute any Corvette dealership would let a brand new Corvette hit the street without checking everything out before delivery.
Unfortunately, it happens quite a bit. There were a significant number of F55 equipped C5s that left the dealer with the "shock stuffers" still intact. Every time there was a complaint about a harsh ride in an F55 equipped car, they were told to check for the stuffers and then leaking fluid. In the majority of cases, the stuffers were left in place by the dealership.
Ultimately, it is a minor hiccup in the roll out and it seems that GM has notified everyone and is taking care of it.
Old Dec 30, 2013 | 03:31 PM
  #56
ndotti's Avatar
ndotti
Is there, in fact, a recall or notice or something official on this? Something I can point my dealer to? I was told they'd "not heard of this."
Old Dec 30, 2013 | 07:20 PM
  #57
1Bridog's Avatar
1Bridog
Default Recall
Hi...
The dealer I went to (Glendora Chevy, Calif). They said they saw a recall in the "system"
To Recall for Diff.
Old Dec 30, 2013 | 10:51 PM
  #58
garwood94's Avatar
garwood94
There is a recall! My dealer verified this and when he checked mine {#1040} it was about half a quart low. He also said to go out and do a bunch of figure 8s - man I hated to do that but I made the sacrifice and did it anyway. This car really turns fast... Anyway I would get the dealer to check it out, under warranty of course, to document the findings.
Old Jan 7, 2014 | 10:57 PM
  #59
Baron7700's Avatar
Baron7700
I got a call to bring it in. havent had a chance yet. Im #692
Old Jan 8, 2014 | 09:45 AM
  #60
Chip A's Avatar
Chip A
Link to service bulletin:http://www.stingrayforums.com/forum/...uid-level.html
