MTI Racing C7 Corvette Coilover Suspension
Old Dec 7, 2013 | 11:23 AM
VIN666's Avatar
VIN666
Not a lot, just a few that don't understand how bolts work...
Old Dec 7, 2013 | 04:38 PM
brokenparts's Avatar
brokenparts
Originally Posted by VIN666
If you guys run into the Turn10 at the track, make sure you kick 'em in the teeth for not including the C7 in Forza 5
Im sure it will be in the game as downloadable content, along with all the other awesome things intentionally left out so they can make a bigger profit
Old Dec 8, 2013 | 09:46 PM
ChucksZ06's Avatar
ChucksZ06
Nice work on the shock mounts. As far as your track testing goes how do you think the car stacks up against the c6z's as far as lap times are concerned?
Old Dec 9, 2013 | 10:47 AM
MTI RACING's Avatar
0MTI RACING
Former Vendor
Originally Posted by C6_Demon
Those mounts look like they will work, but I can't imagine that it will provide any durability. Those loading forces are going to be a bi##h
I wouldn't worry, the engineers have everything sorted out.
Old Dec 18, 2013 | 10:38 PM
ls1torq's Avatar
ls1torq
Thanks for sharing your development and video!
Question: Do your engineers find that fitting the widest recommend tire on a rim result in quickest lap times? (Example: 315's on a 10.5 wide rim or 295's on a 10.5 wide rim)
THANKS!
Old Dec 19, 2013 | 09:22 AM
Z06Ronald's Avatar
Z06Ronald
Sorry if I sound dumb, but what is the advantage of your setup compared to MSRC?
Old Dec 19, 2013 | 10:31 AM
MTI RACING's Avatar
0MTI RACING
Former Vendor
THANKS!
Generally the wider the tire the more grip. Assuming that you don't go to big for the wheel. For example a 335 on a 9 inch wide wheel just won't work.
Old Dec 19, 2013 | 11:11 AM
ls1torq's Avatar
ls1torq
Thank you for your input from experience. Yes, I agree - tires must be mounted on a recommended rim width.
I've been doing some research on what size tire to mount on my C5 z06 18x10.5's and I have found tirerack, manufacturers, and a few individuals recommend a 295. Tirerack states the widest rim should be selected out of the recommended range for a tire. I have found auto manufacturers and SCCA racing teams follow similarly.
I have had the assumption that the widest tire on a recommended rim may not produce lowest lap times or driver feedback due to sidewall deflection characteristics when cornering/changing directions.
Old Dec 20, 2013 | 03:18 PM
Croc999's Avatar
Croc999
i think the right way is to decide on tire width first and then choose widest posible rim.
