Could be a part defect? Or do they show up sooner then later?
For those who dont know, PowerLabs has a lot more experience with engines then most of us here.
I was also not pointing out that because Nissan does this with the new GTR that we should all follow suit with the new LT1, rather, debunking your doubt of what other high end manufacturers do.
To completely ignore the specific advice of the designers, builders, assemblers and go out and "beat the hell out of it" has got to rank with the most stupid advice ever typed into the internet!
When asked by the GM rep why you spun a brand new engine when told not to, are you gonna say..."some guy on the internet told me to"?
Stupidity of breathtaking magnitude.
Stupidity of breathtaking magnitude? Why dont you go do just a little research on how to properly break in an engine and tell me what you come up with? I am willing to bet you wont do one google search Or how about you call a few supporting vendors here and ask them about their LT1s?
Im sure youll just blindly follow what General Motors says though... Came straight from the top, it MUST be true
You'd think with guys writing threads about any issue they are having, we would have definitely seen a number of threads about something like this by now.
The several owners of C7's with blown engines are all at the same dealership, maybe they aren't on the forum nor do they know anyone on the forum and the op just happened to see these several C7's with blown engines at this dealership and then warn us all to break our engines in correctly...
Break 'em in carefully !!! I can't divulge my source except to say several new C7's are back in the dealership with blown engines and very few miles on them. Word is....don't be stupid with it till you have about a thousand miles of break in time.
Der. What a stupid post. Troll alert.
I'm going to drop a bomb, and then not back it up with anything meaninful.
Hey guys, I'm not anonymous, I put my name on it. I saw the fricking cars sitting there with blown motors from jack legs who went out with a new green motor and ran the crap out of it and blew it up. My dealer is remaining anonymous but this is for good warning.
So...what actually "blowed up" about these motors?? Stop being so cryptic.
Your dealer is remaining anonymous? What did they do...take down their sign and shut off their phones b/c a new GM car (supposedly) had a problem?? WHY would your dealer feel a need for anonymity here? Only reason I can think of is b/c they mis-diagnosed a "blowed up motor".
Originally Posted by MasonDixon
This motor is brand new design and not like the small blocks of the past you are referring to.
Yeah, because metal, bearings, oil, coolant...all those things work SO differently in the "brand new design", than they did previously. "rolleyes"
St. Jude Donor '06-'08-'10-'11-'12-'13 '14-'15-'16-'17-'18-'19
Again...der.
And to the OP. This is not necessarily directed at you but rather the fact that too many times, posts like this have appeared and turned out to be nothing. Until you back your post up with facts, evidence, dealer name etc., many of us are going to say "Troll".
Yeah, I just made the whole thing up so I could get a rise out of you wise asses !!! I'm thru with the forum...love my Corvette but not some of the ******** who own them.
Several times the mods have determined that people who started posts like this were previously banned members who didn't even own a C7.
OP...just tell everybody where all of these blown up C7's are residing.
S.
And even with those following the manuals and babying the heck out of the cars, some still can break with certain dealers trying to shade them out of honest warranty repair (used to work at 2 dealers that did this). In the mean time someone else beats the crap out of it at the drag strip with no problems, then takes it in to have warranty clutch work preformed, and gets it.....
Obviously you shouldn't be terrorizing a brand new machine, but come on, all we are saying is break-in is not what it used to be. Also, the definition of what it is to 'beat' on a car varies from individual to individual. Your engine will not explode if you redline it before the recommended break-in period. If engines were really that fragile they would tear themselves apart before 10k miles regardless of which break-in procedure was applied.
All I can tell you as an old (65) petroleum chemist, who has spent a lot of time with engines, metal surfaces take time to seat, even newly machined surfaces. This time is needed even with the newer oils, such as Mobil 1, which keep engine parts away from each other more with a 400% increase in shear-strength. If someone thinks this occurs in a few hundred miles, then I think it will be hard for my personal experience to replicate that thinking. When you look at these mating surfaces under an electron microscope, as I have, after various mileage, you clearly see why engines need time to break in. So for me, I will stick with my oil changes at 1,000 or less miles with a new engine, and at 3,000 miles with a new engine, and at 6,000 miles with a new engine. Then, and only then, will I go to the extended ranges refereed in the owners manual. And, my break in speeds will not be at speeds above highway speed limits and I will shift in the lower RPM ranges. Others can do what they want, and believe what they want, but for me, being involved in over 40 years of this stuff, buying engines from people like John Lingenfelter and building engines myself, I will follow the old school route. I was even talking with a guy last week who said to not prelude a new cam because the new oils do not require it. Huh? Really? Oh well, I like letting the "new" thinkers peal the dollars from their wallets instead of mine. I will stay old school. No offense, but I like the insurance of the old ways. But then I baby ever Vette I have ever owned... because that is the kind of guy I like to be.
I am with Nick Hall.
But I have only been a mechanic for 50 years.
You "Young Bucks" run them the way you want to.
It is your Corvette!
Us "Old Timers" will stick with what we know.
That is the kind of guy I am.
I follow the manufacturer's recommendations on break-in for a new car and have never had any problems. It would be interesting to hear from the OP some definitive answers as to why several C7s at one dealership have had blown engines in them.
People are still living in the 1960's when it comes to engine break-in and maintenance. "500-1,000 miles break in" or "change oil every 3,000 miles". Look up how NASCAR engines are built and broken-in. They start at 2,000 RPM for 7 min, then push it under load for 45 min at over 8,000 RPM to break them in. This is before they are sent to the teams to throw in their race cars.
I just saw a "How It's Made show on the assembly of the new GTR. After every one is built, they have a certified driver beat the heck out of it for 10 miles. They bring it to redline over and over. This is as soon as the car is built. I guess they are all going to have blown engines?
Porsches and other high end cars are broken-in with similar fashion. The idea that you will destroy your engine by not staying under 3K RPM or my favorite, under 60MPH (you can be at 70MPH and still be at less average rpm than cruising around town accelerating to 40), is ridiculous. Like Power said, if your engine blows at an early mileage, it was not due to improper break-in.
Best advice I was ever given as to break-in was when I was in tech school. The instructor for my engine class rebuilt engines for a local Ford dealership for over 20 years. When I asked him about break-in he replied, "how are you going to do most of your driving? If it's on the highway cruising at 60MPH, then break it in as such. If it's on the drag strip running passes all day, then break it in at the drag strip running passes". That's the way I've been breaking in my new cars ever since, exactly the way I would drive it on a normal basis. Never had a single problem doing it that way.
I'm definitely curious though as to the real cause of these engines failing, if it is indeed true on a large scale.
Ha ha ha...so you DID "break it in like you're going to drive it", then! Lol.
As for the bold part; do you still pump the gas 3x when you start it? 'Cause that's how to do it the old way. You warm up your car for 10 minutes before you drive it? 'Cause that's another "old way". Of course neither of these things are necessary anymore...because manufacturing, technology and features have changed to make it easier for the lay-person.
When I bought my C6, I drove it out of the dealer showroom, straight
2000' vertical rise over 5.1 miles...and look at the curves! That was my car's "break in". Car dyno'ed the highest I've seen a stock C6 dyno, and also was the fastest C6 I ever saw at our local track.
I'm not sharing this to say "Beat it to break it in". What I AM saying, is that break-in methods of yore, aren't necessary anymore.
When I bought my C6, I drove it out of the dealer showroom, straight HERE...
No. I drive it like a sports car..... once it is broken in. Not before. I also do not put my spurs on my boots anymore. You have to differentiate between wise and maybe a bit less wise. Our brains are for thinking, it is good to use them for that purpose I think. But hay, be happy and march to a different drummer if you like. Life is best when there are differences. No need to trash people who are different. That is what freedom is all about. Each of us has our own opinion and we need to follow that path. And, if we are wise and considerate, we support other approaches and we always respect others.
I seriously doubt Mr Hall pumps the gas pedal or warms the car for 10 min.
Your experience is a sample size of one which is meaningless statistically. Maybe your engine had a lucky set of clearances that made it a very “happy” product.
I’m on the conservative side and all I would say is that people who adhere to the owner’s manual recommendations and do frequent oil changes will most likely be rewarded with better engine performance and durability than those who flagrantly disregard the recommendations. Don
