2015 twin clutch auto
It's a new 8 speed called the 8L90E... still torque converter based. However, converter based autos have come a long way in the last few years. The latest stuff out there shifts as fast as the average DCT. My guess is the 8L90E will offer blistering performance in manual/race modes and change the way most think about an "automatic" transmission.
Received 2,078 Likes
a dct (dual clutch trans) is not a auto. just as the paddles in a c6 auto dont make it a dct. dct is a manual trans which uses the computer, servos and solenoids to controll the clutch and shifting.
I think there might be some confusion in terminology on this forum. A sequential manual trans uses paddles to shift but you cannot skip gears ie: 1-3. It uses a motorcycle transmission and needs no clutch but upshifts to top and back down again in something like .20 second! It is a manual transmission with no clutch. F-1 and BMW Ferrari etc use this method and most are built by XTRAC.
As to a DCT I think Honda started this tech but I don't know much about it.
The current shift-matching paddle is a component of this type of tranny and I have used this transmission for about 3 years now and it is far and away the best shifting method available for hard fast and precise driving. I would be the first to say it does not replace a standard auto transmission. It does not use any fluid coupling and is direct drive with the ability to easily change internal ratios.
I prefer to call it a an automated sequential manual gearbox and believe the corvette will eventually get one, but it may not be until the C8. Price and power being the current obstacle, ie the 2012+ Ford Focus utilizes one.
Is this the thread you are referring to?
http://forums.corvetteforum.com/c7-z...smissions.html
Yes, they're different internally and the latter is a better/newer design, but essentially both do the same thing.
http://forums.corvetteforum.com/c7-t...n-a-vette.html
Missed that one, curious of your exact field of mechanical engineering?
