Time to upgrade fuel system?
Old Dec 27, 2013 | 10:37 AM
srooper1980's Avatar
srooper1980
Default Time to upgrade fuel system?
Hey guys.. I am currently running 28 lb injectors and stock pump (71k miles).. I have full bolt on's and a 150 shot through a plate system from nitrous outlet.. I am now adding a cam package from Tick.. 233 236 619 578 on a 112.. I know that will put me past the stock system abilities.. Would you guys recomend a BAP??.. a Walbro??.. Both?? And as far as injectors go.. Since its a wet system I only need to support my N/A numbers right?? Since the fuel is added through the N2O system when in use.. Maybe I am on crack lol.. if I need them would you go 42?? or would you go to 60??
Old Dec 27, 2013 | 11:18 AM
Elleby13's Avatar
Elleby13
Think this is in the wrong section. but good luck deciding on injector size!
Old Dec 27, 2013 | 12:28 PM
Trash's Avatar
Trash
There are calculators available (on line) which will help size injectors. 28# injector will carry around 350 hp, 42# injector will support around 535 hp, and a 60# injector will support around 750 hp. The assumptions are 43.5 psi fuel pressure, 8 injectors, 80% DC max and a .5 BSFC.
These are target numbers and not necessarily spot on. As noted, wrong section but good luck.
FWIW, I swapped 24# injectors for 42# injectors in a SBC stroker marine motor and kept the same fuel system with success. No pump mods.
Old Dec 27, 2013 | 12:44 PM
srooper1980
How in the hell did I do that lol.. I have no idea how I got into the C7 section lol.. I will post in C5 if a mod wants to delete this thread
To Time to upgrade fuel system?
