How similar is the C7 diff to previous years? Has anyone done a gear swap yet?
Pat
Bump! Great question. I'd like to change mine out for the same rear they put in the Z51 if possible. I hate not having limited slip and would love the taller gear.
Your car has a limited slip differential, just not the e-LSD
It doesn't mention Limited Slip Differential on the Big Window Sticker that came on the car so I didn't think I had it. What is the difference between what I have and e-LSD?
Wanna laugh?
I asked my dealer why I had no Limited Slip and he called me back to say it was replaced by the Stabilitrack. LOL! Two completely different things.
Wanna laugh?
Your LSD is a normal mechanical LSD.
Here is an explanation of the e-LSD
A smart electronic limited-slip differential (eLSD) is included in the Z51 Performance Package and continuously makes the most of the torque split between the rear wheels. The system features a hydraulically actuated clutch that can infinitely vary clutch engagement and can respond from open to full engagement in tenths of a second. It shifts torque based on a unique algorithm which factors in vehicle speed, steering input and throttle position to improve steering feel, handling balance and traction.
The eLSD is fully integrated with StabiliTrak and Performance Traction Management systems. Its calibrations vary among three modes, based on the Drive Mode Selector setting:
Mode 1 is the default setting for normal driving and emphasizes vehicle stability
Mode 2 is engaged when electronic stability control is turned off in the Sport or Track Driver Modes. This calibration enables more nimble turn-in and traction while accelerating out of a corner
Mode 3 is automatically selected when Performance Traction Management is engaged. This calibration has the same function as Mode 2, but is fine-tuned to work with Performance Traction Management.
That sounds totally great and high tech but does it mean that it's impractical or maybe even impossible to put a 3.90 ring and pinion in the C7?
The Z51 doesn't have a different rear gear ratio. The transmission is geared more steeply in 1-3 and 5th. The base car, as mentioned above, still has a traditional limited slip. The eLSD just adds control of the actuation of it all... think of it like variable cam timing vs. picking a fixed cam profile.
I don't think that answers my question. I used to have a 2008 Z51 C6 with the same transmission ratios as in the C7 Z51. I installed a steeper rear gear in the C6 diff and I loved the way the car drove after that. If I buy a C7, I'm interested in knowing if I can do the same thing? It sounds like nobody has done this yet.
The auto z51 does have a different rear end gear ratio.
So only the auto car's rear ratios are different on the Z51, with the manual rear ratios being the same on both cars. The auto gear ratios are the same on both cars, but the Z5's manual gearbox ratios are all different from the ones on the base car except for 4th gear which is straight 1.00:1
RPM Transmissions (forum vendor) knows the answer to your question if anyone does.
