First Katech Stage 1 C7
Old Dec 31, 2013 | 10:40 AM
Katech_Zach's Avatar
Katech_Zach
Premium Supporting Vendor
C7 of Year Finalist (track prepared) 2019
Default First Katech Stage 1 C7
Just wrapped this up yesterday. This is the first Katech Stage 1 C7.
A complete package list is available on our website here:
http://www.katechengines.com/perform...s/c7-corvette/
How does it feel? I can't really tell right now because it blows the tires off at 3500rpm and half throttle. I guess that's a good thing.
On to Stage 2...
__________________
Contact:
(e) zach@katechengines.com
Old Dec 31, 2013 | 11:01 AM
peter pan's Avatar
peter pan
Life Time NCM #2196
Awesome
Old Dec 31, 2013 | 09:49 PM
Halltech's Avatar
Halltech
Supporting Vendor
St. Jude Donor '09
Default Halltech Flat torque curve vs. stock
4,000 to 5,000 rpm torque curve, except for a spike in the stock curve, is around 20lb-ft more than stock.
Look at what happens to the stock torque at 5,000 rpm, after peak. The drop off to 390lb-ft vs. 416lb-ft. This kind of torque is usable and you will feel the difference.
We saw the same spike at 4,500 rpm on our dyno sheet. If it was not for that bump in the road, over 20lb-ft torque would be the case with the Halltech C7 Stinger over stock.
__________________
"World Class Performance for your Corvette"
Intake Design and Engineering since 1999
Halltech Systems, LLC
423-915-6056
For service email:
orders@halltechsystems.com
www.halltechsystems.com
Old Dec 31, 2013 | 10:09 PM
Turbooo2u's Avatar
Turbooo2u
So this is just with an air-box?
Old Dec 31, 2013 | 10:25 PM
LEAVINU's Avatar
LEAVINU
$2k for an intake and a tune?
Old Dec 31, 2013 | 10:28 PM
kiteboardr's Avatar
kiteboardr
Its well known that stock C7 exhibit an 11-12% drivetrain loss of power when comparing WheelHP to Crank HP , this has been demonstrated time and again by stock dyno runs.
You posted two dyno sheets; one shows 409whp which I assume is stock form?...another shows 424whp which I assume is the dyno run with the intake and tune?...14hp gain over stock ...Your website claims this package makes 510hp. Can you please explain how 424whp translates into 510hp or am I missing something here?
Old Dec 31, 2013 | 10:52 PM
djfury05's Avatar
djfury05
Yea you must be missing your glasses because you didn't see the asterisks next to the claimed numbers indicating there was a cliff note at the bottom of the page...
Old Jan 2, 2014 | 08:26 AM
Katech_Zach
510hp (J607) is the actual horsepower tested on the engine dyno. No translations or extrapolations have been made.
Old Jan 2, 2014 | 08:27 AM
Katech_Zach
Airbox and tuning, yes.
For the carbon fiber version of the airbox, yes.
To First Katech Stage 1 C7
