Thumb drive?
Old Jan 3, 2014 | 09:24 PM
Theta's Avatar
Theta
St. Jude Donor '14-'15
Originally Posted by doug doo wop
This stuff is soooo complicated, just to play music. I'm looking at my laptop which has 3 usb ports but they are not colored. Also the above drive from Walmart can hold 36000 songs, I only have about 10000, so why would I need two of them. I would like to buy a thumb drive tis weekend but I still don't know what to buy. I'm wondering also if this would be compatible with a 2015 vette? Who knows. Thanks for your help.
It's really not complicated at all - I promise!
USB is and has always been backwards-compatible. If you have a USB port, you can use any USB memory stick. Period. The speeds are affected by the revision (2.0 vs 3.0, etc) - the connector is the same. So let's not worry about that.
There was a bit of an error before in bitrate calculation. I would suggest using a single 128GB stick to give you room for expansion plus handle moving everything over from your iPod.
A 64GB stick would be equivalent to having a 60GB iPod, and if you're moving from something approximately that size, there's no room for growth.
So, pick a well-reviewed and reliable 128GB stick (remember, if the stick dies, there goes all the music), fill it with MP3s, and plug her in!
Old Jan 7, 2014 | 06:08 PM
doug doo wop's Avatar
doug doo wop
Hi, I'm back with PNY 128GB flash drive. So before I put my Itunes on this, you said something about formatting? I would appreciate help on this matter, so you can just PM me if you want. Thanks
Old Jan 7, 2014 | 06:24 PM
Theta's Avatar
Theta
It should already be in FAT32. Post the model number if you would, and I'll check if it's in exFAT or FAT32.
Old Jan 7, 2014 | 07:14 PM
doug doo wop
Thanks, this might be the # P-FD128Att03-GE
Old Jan 7, 2014 | 07:45 PM
Theta's Avatar
Theta
Good news: That's FAT32 formatted from the factory.
Copy a few songs over to it first, then stick it in the C7 to confirm playback. If all works as planned, load up the rest of your music!
Old Jan 7, 2014 | 10:21 PM
doug doo wop
Hey that's great but the funny thing is, I don't have a C7 yet. I'm getting a 2015. But for now, I can still put my Itunes on there and that's my back up in case my laptop goes down. Thanks for your help. I don't know anyone with a C7 yet but if someone in my club gets one, I'll test it out.
Old Jan 7, 2014 | 10:39 PM
fdxpilot's Avatar
fdxpilot
Originally Posted by sdk
I would like to see a CD player option.
Are any aftermarket units available?
So convenient to be able to play 10-18 songs on a disk, rather than 4500 on an SD Card.
Seriously, there is an input jack so you if you can find a portable CD player with a headset jack, a connector cord will hook you up. Of course, then you need a power cord or batteries.
On the other hand, I got in the wife's C7 today, said "play Eagles," and had all their albums available. In an auto exterior environment, I'd be hard pressed to tell any difference between a CD and the same song ripped to a 256bps MP3. Our 32GB SD card is only about 2/3 full and has over 4500 songs.
Old Jan 8, 2014 | 05:07 PM
doug doo wop
Questions:
1. is it possible to transfer "playlist" from itunes to flash drive?
2. when you plug in the flash drive in your C7, does come up on the screen and you scroll to what you want to play?
3. If you plug in an Ipod in the C7, how do you choose music. Do you have to scroll the Ipod or does the info come up on the screen in the car? This is all such a PIA!
Old Jan 8, 2014 | 05:25 PM
Theta's Avatar
Theta
Questions:
1. That's up to how you transfer it. iTunes is a fairly restrictive program, and I hate dealing with it. You should be able to export playlists into folders.
2. When you plug the USB in, there will be a USB option that appears on the screen that you may select. From there, you can select the folders, files, etc.
3. The iPod functionality is built-in; you can select songs from the screen.
Not really... it's really a simple design, and I've tried to spoon-feed you along the way.
Be glad that you have (or will have) a car that can interface with newer technology. Many only support simple file interaction (USB is still a luxury to most vehicles even in this day) - and even then, most have limited M3U (tags) reading, which merely shows file name and no other information.
All that, and you have high-quality A2DP for Bluetooth devices (that even works with displaying artist/track names on the windshield HUD) - overall, out of all of my cars, I like this integration the best. Spotify in 4G LTE on max bitrate streaming = perfect. For those that prefer Pandora, that's even built-in to the car directly. Well done, GM.
Old Feb 2, 2014 | 10:08 PM
wosisk's Avatar
wosisk
Ok, I've read a number of threads and still confused. My wife's car is a Buick Enclave, a GM product, plays my cruzer 4GB thumb drive (w/folders) without issue, its a nightmare in my C7, about to give up and buy 1GB thumb drives (smaller if they got em) and forget the folders. Guess it will be like the old days, instead of having a number of CD's I'll have several thumb drives in the side compartment.
Old Feb 2, 2014 | 11:26 PM
Theta's Avatar
Theta
I've not had an issue with folders - perhaps it's something else.
If you can, grab an 8GB (or 4GB if you can still find any - the days of 1GB are long gone since 8GB is dirt cheap), and try testing with files only in the root. If that works, then move on to folders. And if that works, you may just currently have a 4GB stick that's incompatible or has a different format type.
Old Feb 13, 2014 | 09:42 PM
zdr2k's Avatar
zdr2k
64GB SANDISK card works great - I always leave it in there.
Old Feb 14, 2014 | 09:20 PM
  #33
chevy corvette's Avatar
chevy corvette
Everything David said. ^^
The C7's dash unit will play MP3 for sure, and it may also play AAC and M4A. However, lossless codecs such as FLAC, M4A lossless, etc. are not playable (as expected, of course).
I suggest buying a SanDisk Cruzer Fit, as they're essentially invisible when installed (only a few mm tall when plugged in). Cheap - 16GB is less than $10.
Amazon example: Amazon.com: SanDisk Cruzer Fit 16 GB USB Flash Drive SDCZ33-016G-B35: Electronics
Old Feb 14, 2014 | 10:01 PM
  #34
rsvette12's Avatar
rsvette12
What is the largest capacity Cruzer I can use ? thanks Guys
Old Feb 14, 2014 | 10:09 PM
  #35
Theta's Avatar
Theta
I believe you're fine up to 128GB.
Old Feb 14, 2014 | 10:10 PM
  #36
rsvette12's Avatar
rsvette12
Thanks so much Theta
Old Feb 14, 2014 | 10:19 PM
  #37
rsvette12's Avatar
rsvette12
Does 2.0 and 3.0 make a difference ?
To Thumb drive?
Old Feb 14, 2014 | 10:21 PM
  #38
Theta's Avatar
Theta
The car only uses a USB 2.0 interface, but USB 3.0 would be faster in loading files on your PC, assuming your PC has USB 3.0 ports (blue).
USB 3.0 is backwards compatible, so there's no issue either way.
Old Feb 14, 2014 | 10:27 PM
  #39
rsvette12's Avatar
rsvette12
Ah so 3.0 in vet would not make any difference in speed as it is only 2.0 capable - thanks again
Old Feb 15, 2014 | 11:24 AM
  #40
wosisk's Avatar
wosisk
Never did get my C7 to read my folders so I got rid of the folders and created playlists, that works.
