Thumb drive?
Old Jan 2, 2014 | 03:06 PM
doug doo wop's Avatar
doug doo wop
Default Thumb drive?
Hi, I thought I read somewhere that there is a specific thumb drive to use for music. I just finished putting all my cd's in itunes and then to my ipod, but I would just like to use a thumb drive; I'm looking ahead for a 2015 but I also want a back-up for my itunes now. Of course, this thumb drive might be obsolete in next years StingRay but it will still be good for my laptop back-up. Thanks
Old Jan 2, 2014 | 03:32 PM
Daniel@Vengeance's Avatar
0Daniel@Vengeance
Former Vendor
There's no specific type of thumb drive. As long as the USB thumb drive does not have a "read-only" switch (if so, turn it off), and the music is in a file format that can be read by the car, then you'll be fine.
Old Jan 2, 2014 | 03:47 PM
Theta's Avatar
Theta
St. Jude Donor '14-'15
Everything David said. ^^
The C7's dash unit will play MP3 for sure, and it may also play AAC and M4A. However, lossless codecs such as FLAC, M4A lossless, etc. are not playable (as expected, of course).
I suggest buying a SanDisk Cruzer Fit, as they're essentially invisible when installed (only a few mm tall when plugged in). Cheap - 16GB is less than $10.
Amazon example:
Amazon.com: SanDisk Cruzer Fit 16 GB USB Flash Drive SDCZ33-016G-B35: Electronics Amazon.com: SanDisk Cruzer Fit 16 GB USB Flash Drive SDCZ33-016G-B35: Electronics
Old Jan 2, 2014 | 06:30 PM
doug doo wop
I'm really not a computer-type person, so you are talking in a foreign language to me. I looked it up and someone said to use a Fat32 or ntfs file format, whatever that is. So what is the file format of the C7? What size thumbdrive do I need for 410 hours of music plus room for later additions? I sure wish it had a CD player, LOL.
Old Jan 2, 2014 | 06:32 PM
doug doo wop
Amazon example: Amazon.com: SanDisk Cruzer Fit 16 GB USB Flash Drive SDCZ33-016G-B35: Electronics
Can I play my Ipod in the C7?
Old Jan 2, 2014 | 06:42 PM
Theta's Avatar
Theta
If you stick with MP3s, you should not have an issue. FAT32 will be the preferred format choice.
Yes, you can use the Apple to USB adapter and plug it in. It will recognize and playback from the iPod.
Old Jan 2, 2014 | 06:45 PM
yonson's Avatar
yonson
It will also use SD cards, I've got lots of 4 & 8 GB cards laying around that I used to use for photography but now that 32's and 64's are relatively cheap I've switched my cameras to those...
Old Jan 2, 2014 | 06:47 PM
Theta's Avatar
Theta
Yes, but it's the space he's requiring that will eliminate that option as well.
I believe the unit supports SDHC but not SDXC, so keep that in mind of anyone wants to try a 128GB or 64GB SDXC. I should test that...
Old Jan 2, 2014 | 06:58 PM
yonson's Avatar
yonson
Yeah, my 4, 8, and 16's work, I just tried one of my 64's and it didn't work...
Old Jan 2, 2014 | 07:02 PM
yonson's Avatar
yonson
It's currently formatted as exFAT though, the card isn't empty so I can't format it to anything else right now...
Old Jan 2, 2014 | 07:03 PM
Theta's Avatar
Theta
Yep - I wouldn't worry about it. I'm 99% sure it's not SDXC-compatible, which means you're limited to 32GB on SDHC.
Old Jan 2, 2014 | 07:09 PM
yonson's Avatar
yonson
Yeah, I'm not worried about, I can keep 3 or 4 cards in there and switch if needed...
Old Jan 2, 2014 | 08:43 PM
doug doo wop
1 hour @ 128kbps = (128 x 60sec) x (60min) = 460800 kB per hour
460800/1024 = 450 MB = 0.45 GB
410 hours = (0.45) x (410) = 184.5 GB
Flat out, you can't find a USB stick this size that the system will recognize. That's hard drive/SSD territory.
I appreciate all the input, so how many thumb drives would I need?
Old Jan 2, 2014 | 08:47 PM
sdk's Avatar
sdk
I would like to see a CD player option.
Are any aftermarket units available?
Old Jan 2, 2014 | 09:21 PM
Theta's Avatar
Theta
No problem!
You could use 3 or 4 64GB USB sticks, or use 2 128GB USB sticks. Even with those large sizes, make sure to have them formatted in FAT32. exFAT and NTFS will not work correctly. This isn't hard, and most will come pre-formatted as FAT32.
An example of a few reliable 64GB sticks:
Amazon.com: SanDisk Cruzer 64 GB USB Flash Drive (SDCZ36-064G-AFFP): Computers & Accessories Amazon.com: SanDisk Cruzer 64 GB USB Flash Drive (SDCZ36-064G-AFFP): Computers & Accessories
Amazon.com: SanDisk Cruzer Fit CZ33 64GB USB Flash Drive (SDCZ33-064G-B35): Computers & Accessories Amazon.com: SanDisk Cruzer Fit CZ33 64GB USB Flash Drive (SDCZ33-064G-B35): Computers & Accessories
Amazon.com: SanDisk Cruzer Glide USB 64GB Flash Drive (SDCZ60-064G-A11): Computers & Accessories Amazon.com: SanDisk Cruzer Glide USB 64GB Flash Drive (SDCZ60-064G-A11): Computers & Accessories
An example of a few reliable 128GB sticks:
Amazon.com: PNY 128GB Classic Attach Flash Drive (P-FD128CLCAP-GE): Computers & Accessories Amazon.com: PNY 128GB Classic Attach Flash Drive (P-FD128CLCAP-GE): Computers & Accessories
Amazon.com: PNY Attache 3 128GB USB Drive (P-FD128ATT03-GE): Computers & Accessories Amazon.com: PNY Attache 3 128GB USB Drive (P-FD128ATT03-GE): Computers & Accessories
Amazon.com: SanDisk 128GB SDCZ60-128G-A46 Cruzer Glide USB Flash Drive: Computers & Accessories Amazon.com: SanDisk 128GB SDCZ60-128G-A46 Cruzer Glide USB Flash Drive: Computers & Accessories
Old Jan 2, 2014 | 09:23 PM
Theta's Avatar
Theta
I can't imagine a proper way to replace the entire screen mechanism with the usual Double-DIN type method.
Perhaps we will find an adapter or protocol hub to tap to add a player.
Or...
SORRY - HAD TO!
Old Jan 3, 2014 | 10:11 AM
doug doo wop
Thanks, this is really great info for me. I would rather just have 2 drives, so which of the 128GB would you recommend, because the only difference that I see, is the cost. AND how do I know they are formatted to Fat32 and if not, how do I get them formatted to Fat32? I appreciate your help.
To Thumb drive?
Old Jan 3, 2014 | 03:25 PM
doug doo wop
Share this:
This is at Walmart for $108 shipped and good for a computer with a 2.0 usb port. Can't find out what my usb port is.
PNY 128GB USB 3.0 Flash Drive, 2 Pack Value Bundle
Old Jan 3, 2014 | 03:28 PM
Theta's Avatar
Theta
USB 3.0 is backwards compatible with USB 2.0. You will be able to visually identify a USB 3.0 port by color - 3.0 is blue, 2.0 is white or black.
In all my years in IT, I don't think I've seen a USB stick ship with NTFS (for obvious reasons - MacOS, etc). Once you get them, if you need formatting instructions, let me know and I'll walk you through it.
Old Jan 3, 2014 | 08:25 PM
doug doo wop
This stuff is soooo complicated, just to play music. I'm looking at my laptop which has 3 usb ports but they are not colored. Also the above drive from Walmart can hold 36000 songs, I only have about 10000, so why would I need two of them. I would like to buy a thumb drive tis weekend but I still don't know what to buy. I'm wondering also if this would be compatible with a 2015 vette? Who knows. Thanks for your help.
