Old Mar 25, 2015, 03:37 PM
How-Tos on this Topic
Last edit by: IB Advertising
See related guides and technical advice from our community experts:
Browse all: Interior How-Tos
Print Wikipost
Door panel removal procedure?
Old Jan 6, 2014 | 08:32 PM
vetehead's Avatar
vetehead
Default Door panel removal procedure?
Can someone that may have the door panel removal procedure please post up??
I would like to remove my drivers side panel to go after 2 minor problems.
Thanks in advance,
Ron
Old Jan 6, 2014 | 10:47 PM
48supertruck's Avatar
48supertruck
Thanks in advance,
Ron
The quick write up is, make sure the window is up before you start. Remove the two torx head screw along the very bottom edge. Pop out the hidden access plastic panel under the armrest to reveal a hidden bolt. Remove bolt. Use a plastic panel tool to pry the door release button aluminum housing out and you will find another hidden bolt. Remove that bolt and then you can use a door panel pop tool to go around the perimeter and pop each plastic clip tha is holding the door panel in place. The clips that are along the top of the door panel pull straight out. The upper window rubber/felt will stay on the door. Disconnect the wiring plugs and the panel should be off by now. I am writing this from memory from a month ago. Forgive me if it is not exact. The two hidden bolts are the key and if you have removed door panels in the past, these are no big deal. Here is what it looks like when the panel is off.
Old Jan 6, 2014 | 11:59 PM
Pete@Showstopper's Avatar
Pete@Showstopper
Supporting Vendor
St. Jude Donor '14. '17
Andrew from thedoubleAA.com posted up a writeup on how to install his image lights. And in there is how to do this. He is a vendor here as well
Old Jan 7, 2014 | 05:40 AM
vetehead's Avatar
vetehead
Thanks,I did a search and came up empty,if you have access to the link could you post it in this thread or pm it to me??
Thanks!
vetehead's Avatar
vetehead
Thank You
Old Jan 9, 2014 | 01:00 PM
Andrew6@TheDoubleAA's Avatar
0Andrew6@TheDoubleAA
Former Vendor
Houston Events Coordinator
St. Jude Donor '11-'12, '14
I believe in the Beer Fairy
http://forums.corvetteforum.com/c7-t...-specific.html
Old Jan 9, 2014 | 03:50 PM
vetehead's Avatar
vetehead
Thanks, that's exactly what I needed!
Old Jan 9, 2014 | 04:27 PM
Former Vendor
no problem, glad it helps you.
To Door panel removal procedure?
