Katech C7 Carbon Fiber Decklid With Optional Lexan Rear Window - PREORDER
Premium Supporting Vendor
I believe this will be a great addition to the C7 and there are enough people here willing to do this.
The C6 weight savings is 34lbs with -3 pre-preg. The C7 decklid will likely come slightly under that because the glass savings won't be as much. The "lexan" is actually optical grade polycarbonate with scratch resistant coating. Fastening hardware will be stainless.
You can pre-order here:
http://store.katechengines.com/c7--c...ndow-p402.aspx
If you would like the decklid without the window for you to either install lexan or glass yourself we will have that available also here:
http://store.katechengines.com/c7-ca...klid-p403.aspx
Shipping is additional and will be determined and charged when they are ready for shipment.
Now that there are a lot more C7s produced is this something what we should re-consider?
