Supercharging the LT1 and Long Term Reliability
#63
I've seen factory forced induction cars blow up on the track at stock boost levels before. Was it not properly engineered?
How about the fact that using launch control on a GT-R will void the warranty? Does that mean it's not properly engineered because Nissan doesn't have confidence in durability of a factory set up?
Boosting a factory NA engine doesn't automatically make something not properly engineered.
Using forged internals is hardly an engineering marvel.
#64
Honestly, do you know how difficult it is to install a H/C setup on an LT1? And it doesn't make the same amount of power - in fact, around 75whp less from current graphs.
It's also a different animal. Many people do not like the cam feel/sound, and it's going to run more than $5k for a proper setup from VR or LMR.
Also, you're going to run into issues going that route as well if we're talking about fueling, etc.
#65
St. Jude Donor '14-'15
My points stand...
Also, it's 7-8psi, and nobody is concerned except those that are playing on the sidelines.
I guess all of the FI companies are just going to have a lot of explaining to do when all the kits blow up, right?
That's going to happen according to your statement...
#66
The thing to keep in mind with a car is this:
They are engineered as a system, to meet several competing goals. Reliability, performance, cost, weight, economy, all play into the design. The transimission will be sized to take the stock loads, and will have high margin against unplanned loads, but will have limits due to cost, weight, and efficiency requirements. Increase the power significantly, and that margin will erode. Road racing is very tough on the car, so reducing margin should be considered very carefully if tracking is your intended use.
Consider the case of adding big power and then tracking your car. Your brakes will no longer be sized properly. You'll be hitting much higher speeds and will need better brakes ($3000+ for a good BBK). How will your drivetrain hold up? Will you need to upgrade transmission/oil/water coolers?
What if you update the suspension to corner better? How will be wheel bearings do? How is tire life affected? How is the ride?
One mod can easily cause a cascade effect that drives more and more mods.
It is quite fun, but also can get expensive quickly.
My 350Z has a number of suspension mods, R-comp tires, BBK, gear limited slip diff, and has held up very well all things considered (no power mods), so I'm not discouraging mods, just saying that big changes will have a cascade effect that may drive more updates down the road. Plus once you "break the seal" on mods, it is sometimes very difficult to stop.
Speaking of which, I wonder how an updated exhaust would sound?
If I were thinking of going forced induction on my Vette soon after purchcase, I'd probably try and wait until more is known about the Z06 and would go that route if I could afford it. Might actually be less expensive in the long run. Until you start modding the Z of course!
-T
-T
#67
My points stand...
Vengeance Racing strikes again with another C7 Stingray build!
One of our Tennessee customers had his car to us after only driving it TWICE! This automatic Z51 received a VR custom camshaft kit, American Racing Headers longtube headers, lowered suspension, green air filter, and a custom ECU calibration. The results were amazing:
492rwhp / 452rwtq !!!!
Stay tuned for more Vengeance Racing modified C7's in the future!
#68
What is your point? We can read the threads. VR also installs blowers, and is really excited to put together their head/cam/ECS blower kit.
Are you going to call them out on it after praising their H/C kit?
#69
Jesus Christ, a last word freak... get over it the OP asked for opinions, i gave mine.
#71
And lets not forget that Callaway has a supercharged 610 horsepower car that legitimately is honored under warranty by GM. GM allows a full factory warranty to be maintained on a 610 horsepower (535whp) supercharged, factory stock LT1 internals, because it will be reliable at that power output, so much so that GM is confident that the stock LT1 will NOT break. You can even apply an extended warranty to it for an additional two years.
If that doesn't convince the doubters, then screw em and their ignorance and stupidity. Harsh to say, but I keep it real. This is getting ridiculous.
#72
How did a thread asking about superchargers and reliability, turn into a "Way to go vengance Heads Cam" thread? holy turn around. Not to mention comparing a factory boosted car with millllllllllions of dollars and countless years of engineering in it, to a C7 with a 7psi blower kit.
#73
The thread has pretty much run its course.
The facts lined up incorrectly for some posters, and when reason failed, the personal attacks and appeals for other power methods started.
Some people are never satisfied with the answer they don't wish to receive.
#74
Lol, seriously.
#75
Case in point....I'll take 492RWHP over a blown motor
#76
This question has less to do with the design of the motor, and more to do with "real" tuners, vs. guys that have HPtuners and EFIlive and can make something live on a dyno. Spending weeks to develop a FULL tune, and really getting to know all the tables and how they work on this new E92 ECU......VS. 30min tweaking fuel and the main timing table.
The motor is strong enough, the power levels that all current supercharger kit producers are making is VERY safe.
When on a road course lots of things come into play that do NOT on a dyno, but whats nice about GM is that they have a VERY amazing ECU, that has LOTS of ability to take these factors into consideration. (After all they make a couple supercharged road course monsters, IE: ZR-1)
So as long as your tuner, takes those factors into consideration, you will have NO issues, with lots and lots and lots of supercharged miles.
EA
EA
#77
All, not just vengeance, are "testing" blowers kits yes. Maybe you guys dont understand the definition of testing. They are all going to see some issues as they always do. There will be a limit to the boost and romping. If you want to be on the bleeding edge, go for it if you can afford it. If the LT1 is so bomb proof, why didnt GM just slap a blower on it and let it roll in the Z06?
Blowers can be added to any vehicle sure, but how long will the cast parts hold out was the question. All I said was that I prefer a heads and cam set up over a blower set up on a stock bottom end. Its just funny to have my opinion attacked by a person who doesn't have enough common sense to jack a car off the ground safely. God bless the internet.
#78
I had a nightmare with heads and cam. I think somebody mentioned this. With a blower, the only time it really effects/changes the car is under heavy to full throttle, right? With a cam, everything is changed completely. When I did heads and cam on my last car, the car couldn't even idle properly, and would stall when braking or if you breathed to abruptly. It took a year and a few thousand dollars of going back and forth to different tuners to stabilize the car. So that is why I asked the question about blowers. To my understanding, they are more simple to install and tune properly, and run more stock-like than heads and cam with normal driving, but the power is there when you hit the go pedal.
#79
As far as why doesn't GM just throw a blower on the car and sell it as a Z06 is that it will obviously make the price of the car jump dramatically. They have different trim levels/models of cars for a reason. If they want an introductory price of $51k they can't obviously supercharge it. That is the reason that they have had different models all along. And with the price/performance increase they are of course going to make certain parts stronger.
As far as living on the bleeding edge of technology, me personally I want a SC on my car because I do a lot of car shows/cars and coffee event as a way of networking with my business. I don't plan on tracking my car, racing my car, but I do enjoy being able to open it up every once in a while to feel the exhilaration of speed and acceleration. It is in my understanding that adding 100hp and not constantly ragging on the car is not going to make my car blow up. (taking into account that it is installed and tuned professionally and correctly)
I just found it a little odd that someone who works for performance shop modifying cars and installing and selling superchargers, Nitrous, etc kind of made a hint that if you put a supercharger on your car it will blow your engine. If you put on a supercharger for a customer do you tell them that it will blow their engine? Not trying to argue just a valid question.
#80
Doesn't the supercharged LSA use cast parts? While forged is certainly stronger than cast, I think the bigger concern is the compression ratio.
