So I will be taking delivery of my C7 about 150 mile away from home. My intention is to drive it home but, is that good idea, what is the proper break-in procedure? it is mostly highway going from NJ to Long Island NY so it could be stop and go all the way!
thanks
So you just took delivery of your new 2014 Corvette Stingray and now you got questions about how to properly break-in the 455/460 hp LT1 V8. With more Corvette Stingrays being delivered daily to their new owners, we’ve been asked the break-in procedure question more than a couple of times. So we’ve checked out the Owners Manual and have the recommended new vehicle break-in procedures straight from General Motors.
We’ve all seen the videos from some of the tuners showing new Stingrays on the dyno, doing burnouts, quarter mile runs and even a top speed run where the Stingray hits 175 mph with only 215 miles on the odometer. According to GM, these practices are not recommended until the Corvette Stingray goes through the break-in period.
GM has the following recommendations for 200, 500 and 1500 miles. They say that following these guidelines is recommended as parts have a break-in period and performance will be better in the long run.
For the first 200 Miles (322 km):
To break in new tires, drive at moderate speeds and avoid hard cornering for the first 200 miles (322 km).
New brake linings also need a break- in period. Avoid making hard stops during the first 200 miles (322 km). This is recommended every time brake linings are replaced.
r the first 500 Miles (800 km):
Avoid full throttle starts and abrupt stop.
Do not exceed 4000 rpm.
Avoid driving at any one constant speed, fast or slow, including the use of cruise control.
Avoid downshifting to brake or slow the vehicle when the engine speed will exceed 4000 rpm.
Do not let the engine labor. Never lug the engine. With a manual transmission, shift to the next lower gear. This rule applies at all times, not just during the break-in period.
For the first 1500 miles (2414 km):
Do not participate in track events, sport driving schools, or similar activities during the first 1500 miles (2414 km).
Check engine oil with every refueling and add if necessary. Oil and fuel consumption may be higher than normal during the first 1500 miles (2414 km).
Well, you have to drive it to break it in...........stop and go is fine. What you DON'T want is a high load on the engine and a prolonged steady speed.
St. Jude Donor '05-'06-'07-'08-'09-'10-'11-'12-'13-'14-'15-'16
St. Jude donor in memory of jpee '14
I am surprised the list did not mention the different heat cycles for break in of the differential & gears.
Gents,
what is considered a "high speed".
While I am on the parkway if I vary speed between 50 to 65 mph for about 100 miles then the final 50 miles will probably be in the 45 to 60 mph, is that good?
Gents,
That is more than fine, even 90 mph would be okay (keep in mind the car does over 185 mph).
You want to avoid triple digit speeds until it is broken in; and just as important anywhere near full throttle starts or rpms over 4,000.
If one is taking delivery from the museum (if your car doesn't get swallowed up, haha), and driving back to Texas, what would be the suggested break in? Would it be best to take back roads instead of the major highways to get lots of varying speeds?
You can vary the speeds on the highway...ie pass on left and then back to right....drive speed limit some, under speed limit some, take hourly rest breaks after drinking plenty of water so those bath room stops are more frequent. That first 500 miles will go by pretty quickly.
If you are going to be on the highway, don't keep it in 1 gear.
Drop down to 4th or 5th or 6th in a manual or 4th/5th in manual mode on an auto. While your fuel mileage won't be great, you will get a varying range of RPM if you change your speeds slightly.
So the main concern is varying engine rpm's, not so much varying driving speed?
Just drive the car like you're going to drive it, avoid beating the crap out of it for the first couple hundred miles and you'll be good to go.
I have had High Performance cars for over 50 years never had a slow one, broke all of them in the way I planned to drive them, which included getting on it every once and while. Old sand cast blocks back in the 60's were loose these babies are almost exact don't act the fool but enjoy your car. I agree not to track the car or go crazy on the stop and go. Again as always just my humble opinion.
Love my C7
Love my C7
CC,
thanks, that is what I have done in the past however, I never bought a car from a place that was so far from my home. So being on a highway for 100+ miles, is something new for me, it makes sense to just change the gear (RPM's) as that is really changing the speed of the engine.
thanks,
Joe
