distributor/coil issue
Old Feb 14, 2014 | 07:07 PM
windemere's Avatar
windemere
Default distributor/coil issue
I have a 72 vette, base 350 engine. I'm rebuilding the distributor (it wobbles and won't advance timing), and am installing a Pertronix II module in place of he point and condensor. I also want to put in a Pertronix coil. Here's my question(s): I have three wires coming off the positive side of the Delco Remy coil. One is for the ignition coil condenser (?), mounted at the base of the coil. There are also a red and black wire which disappear into a wiring harness. How do i tell if i have a resistor wire (I don't see a yellow wire), or a ballast resistor. And what wiring changes do I have to make to change over to the hotter coil?
All help appreciated. Thanks.
Windemere
Old Feb 14, 2014 | 07:20 PM
Theta's Avatar
Theta
St. Jude Donor '14-'15
Wrong section.
Old Feb 14, 2014 | 08:21 PM
windemere's Avatar
windemere
Originally Posted by Theta
Wrong section.
Oops. Fat fingers. Thanks
To distributor/coil issue
