C7 Production Systems - PICS
I sent you a PM what if I swiss cheese
that bracket a little with a drill. if done right it should stay strong and be lighter.
CARB approval, hopefully utilizing GM injectors as is, will simplify that a little (one less component to nail from calibration matrix standpoint).
Jim Hall
"World Class Performance for your Corvette"
Intake Design and Engineering since 1999
Halltech Systems, LLC
423-915-6056
For service email:
orders@halltechsystems.com
www.halltechsystems.com
You can see that we've continued with the "Ram Air" intercooler design.
The scoop is open to the front and completely sealed against the intercooler at the rear and sides. With the horizontal orientation of the core you must actually FORCE the air to change direction. Air will always take the path of least resistance and must be forced through the intercooler core.
The back of the scoop is at a 45* angle to the actual core. What you're seeing is the reflection of the cooling fins in the back of the scoop. The front lip of the scoop is folded over 180* just to give it a nice rounded edge. It also strengthens it.
The first picture is deceiving in that it appears that the core and tank are visible from the front of the car. They really aren't. I was shooting down at an angle. The surface of the core is actually about 1/2" below the bottom of the grill opening. Only the scoop extends up into the grill area.
The second picture is what you actually see from the front of the car.
And, yes, I know my car is dirty!
The grill opening is enclosed with a large cylindrical shroud that seals up against the radiator. Air inside this shroud is definitely going to be under increased pressure at speed. Grabbing a portion of this air and actually forcing down through the intercooler core is, in my mind, the most efficient use of the intercooler core.
PLEASE TAKE A MOMENT TO VISIT OUR WEBSITE AT WWW.AACORVETTE.COM
NOW PARTNERING WITH AFFIRM TO OFFER INTEREST FREE FINANCING!
ANDY GREEN- OWNER/ CEO -A&A CORVETTE / A&A SUPERCHARGERS
477 LAMBERT ST
OXNARD CA 93036
WWW.AACorvette.com
A&A CORVETTE SUPERCHARGER SYSTEMS
HOME OF THE WORLDS FIRST
CENTRIFUGALLY SUPERCHARGED C7
SUPERIOR ENGINEERING- SUPERIOR POWER
SUPERIOR PRICING- SUPERIOR CUSTOMER SUPPORT
Andy@AACorvette.com 805- 278 4107
Yes. It fits just fine. It's just not shown in the pictures.
Dropping temps by well over 100* is normal.
Even on the dyno, where fans can't even come close to forcing the volume of air through the cooler as would a vehicle traveling even, 80MPH, the temperature drops are huge.
With our ram air design, all the air that hits the front of that scoop is forced through the core. Nobody else's design comes close to being that efficient.
The short answer? Yes, the intercooler is necessary for an efficient system.
Andy I certainly do not wish to bicker back and forth, but this is 100% false information. Frankly it's a bit of a "low blow" and I was hoping we could be done with that stuff, but I'll leave it up to you which direction these things take. You have my word that I will not poke at you unless instigated in a matter such as this.
Paxton Vortech has used restrictor plates in their own kits for a long time and actually suggested we used them when we switched back to Paxton. They are absolutely aware that we use them, and no one has ever, or will ever be denied a warranty claim because of one.
It's a simple, yet effective way of creating more low end boost, with no negative side effects As we have been proving for almost ten years now.
I was asked and I'm telling him why I don't use them. Nothing more. Nothing less.
