C7 Procharger System Delivery
I know ECS can do all that and has great customer support which is one of the reasons I recommend and use their systems. Doug/Chris/etc are all great to deal with. Hell, call Matt@FSP for tech questions since he worked there forever. He is super helpful too and a great source for all things ECS too.
Naturally I'm biased to an ECS kit, but truth be told, your decision should not be made on when it will come within reason, whether or not a T-shirt is included, or that we do not bill until the kit is packed.Your decision should be made on what the final outcome of your purchase will be for many years to come, and the quality of the parts included with the kit. Break down both systems part for part and purchase the one that you feel is right for you.
Compare them part for part! A&A has the T-shirt too!
1030 at night I called Andy answered.
First rate service at A&A!
You can order any blower OR ANY KIT you like!
Thank you sir! Vengeance called me earlier regarding this.
The critical deciding factor right now for early adopters is the amount of personal attention and support available at the moment it is needed whether to answer a simple question or to address a major tuning issue.
Like I said, I like the Procharger kit and I hope they step up to support their product just as Doug and Andy has. Your move Procharger.........
Then I was wondering if the filter is in the box when your doing 750 rwhp?
Because pulling the filter raise's the output. That's why A&A includes the hi -flow Air filter.
The stock paper filter is a major restriction.
Dealer kits get sent without usually, PM me your address and I'll get one sent! ThanksThen I was wondering if the filter is in the box when your doing 750 rwhp?
We didn't switch our air flow? We offer it in both directions but have never had the request for top down yet, but I suggest following the OEM airflow of bottom to top. I also do not care for taking away 25% of the airflow to the radiator, but technically it is less expensive for me to add the air dam up top down then adding them below. Intercooler placement is identical.
We also have the option for the Air filter and sent them on all the original kits, we just had a window where they were not available from Green.
That said, someone looking for 550 rwhp from their kit is not going to see any significant gains from adding one, so if you would like to deduct that from the kit we are fine with that. Save a few dollars!
I need to work on our "official ECS SC" thread so this is more clear, I just held off until things are full speed here. We have several options from mild to a ten rib 2200R wild kit. I just held off because the orders are coming in so heavily that we are working at max speed. (thank you!)
That all said, I'm not saying you made a bad choice, I'm sure you will love your kit and great customer support as always!
C5/C6 and C7 Supercharging Specialist
ECS Supercharger Kits / Mantic Clutches
www.EastCoastSupercharging.com
Facebook Page
ECS YouTube Channel
