Leak
Old Mar 17, 2014 | 03:29 PM
tnspd's Avatar
tnspd
Default Leak
Ok, I put the wifes C7 on my lift yesterday and noticed a drop of fluid starting to form under the right front side of the engine. The oil looked green in color so I know it was not antifreeze because it is orange. What could be leaking that has a green color fluid in it? I could not tell where the fluid was coming from. It is pretty cramped space under there. There has been no drops on the floor of the garage either.
Old Mar 17, 2014 | 03:36 PM
lgodom's Avatar
lgodom
I believe some members have reported greenish oil, maybe due to a dye. So, it could be engine oil if it feels like it.
Your user name looks familiar. Did you happen to trade in a 5th gen Camaro for the C7?
Old Mar 17, 2014 | 03:44 PM
tnspd's Avatar
tnspd
No, I have a 5th Gen Camaro SS, a 5th Gen ZL1 Camaro , and this C7.
Why would die be in my oil. I have not had it to the Dealer to put die in it? Maybe it is residual oil with die in it from the factory when they checked it or something?
Old Mar 17, 2014 | 03:49 PM
Theta's Avatar
Theta
St. Jude Donor '14-'15
Green, as I learned yesterday, is the dye they put in the AC system to check for leaks.
How do I know? I unbolted the wrong bolt and had some r134a spray out at me. Green dye bubbled and dripped.
Old Mar 18, 2014 | 09:19 AM
tnspd's Avatar
tnspd
So it could possibly be an AC fluid leak?
Old Mar 18, 2014 | 10:00 AM
travisnd's Avatar
travisnd
GM also uses green thread sealant sometimes. The green is designed to seep into threads after a bolt is tightened I believe. FWIW I bought a new LS2 water pump for a race car build and the heater core ports had excess green goo on them from where they were pressed into the water pump housing. Had to clean it off before install. It was like green sealant. Might be something like that.
Old Mar 18, 2014 | 10:20 AM
tnspd's Avatar
tnspd
I'll clean it all up and keep an eye on it to see if it returns. If it does I'll take it to the dealer I guess.
I just like to know what the problem is before I take anything to the dealer. That way I know what the dealer is suppose to be doing to fix the problem. I have seen too many dealers mechanics just guess at what the problem is by changing parts until the problem is fixed.
Old Mar 18, 2014 | 05:03 PM
Theta's Avatar
Theta
It's the same as Loctite Green. It's a slow-acting penetrant.
That will show up as a dark green color, while the AC dye will be a lime green color.
Hope that helps.
Old Mar 18, 2014 | 05:15 PM
LT1xL82's Avatar
LT1xL82
Originally Posted by tnspd
I'll clean it all up and keep an eye on it to see if it returns. .
You might want to drag your feet cleaning it up. If it is green Loctite may still "wick" its way into threads. The stuff works via capillary effect and it can take a fair amount of time.
Old Mar 19, 2014 | 01:59 PM
tnspd's Avatar
tnspd
This fluid is a lime green color so it must be AC fluid. It is very thin feeling, not thick at all.
Old Mar 19, 2014 | 02:09 PM
Theta's Avatar
Theta
Bingo - AC fluid. If it's leaking up toward the nose, check the two bolts holding the pressure hoses to the condenser. If it's farther back, swing it by the dealer.
Now you can tell them what it is so they don't have to hunt or say 'we don't know'.
Old Mar 21, 2014 | 08:43 PM
SpaceCadet's Avatar
SpaceCadet
Cruising
Agreed prob. from AC system...
Green Loctite is for permanent applications, not threads
Old Mar 21, 2014 | 09:04 PM
Theta's Avatar
Theta
It's great to use on seized threads, as I've found out several times before with seized turbocharger studs. Back a nut onto them, Green Loctite, wait 24 hours, pop them out.
Also, it never occurred to me to mention it, but even Green Loctite cures fully within 24-36 hours, the the drip/drop would be either gooey or solid.
So AC it is.
To Leak
