*WARNING* to ALL BOOSTED C7s
Old Apr 1, 2014 | 01:40 PM
  #61
Theta's Avatar
Theta
St. Jude Donor '14-'15
Originally Posted by jspridge
Thank you Doug for providing an easy solution for all of us. Would you (or someone) be able to provide a picture of the hose and check valve in question here?
Thanks in advance!
I believe this is the culprit. Note that these are all black now, this pic was from a pre-production model but I was in a hurry.
Old Apr 1, 2014 | 01:50 PM
  #62
RpeterK's Avatar
RpeterK
Default pics
The ball looks to be made of aluminum and has little weight to overcome any buildup. Once stuck it will not allow anything to pass.
Old Apr 1, 2014 | 01:57 PM
  #63
Theta's Avatar
Theta
Oh holy crap, that's even worse than I thought - I figured it was just a plastic ball that would be easily tossed around. No wonder these are getting stuck...
Old Apr 1, 2014 | 02:03 PM
  #64
jspridge's Avatar
jspridge
Great pictures - thanks! Do you need a tiny hole saw to remove that ball?
Old Apr 1, 2014 | 02:20 PM
  #65
RpeterK's Avatar
RpeterK
It you take a little scribe with a 90 point you should be able to hook that plastic piece and get it out.
Old Apr 1, 2014 | 04:13 PM
  #66
Motohead279's Avatar
Motohead279
I'm definately doing this tonight.
Old Apr 1, 2014 | 04:14 PM
  #67
jspridge's Avatar
jspridge
Same here. Thanks very much for all of the information!
Old Apr 1, 2014 | 04:18 PM
  #68
Dameian's Avatar
Dameian
See what happens when we all work together!!!
Old Apr 1, 2014 | 04:30 PM
  #69
Theta's Avatar
Theta
Things have gotten a lot better in the last week. We can finally all start working together instead of fighting with 17 usernames that all want to argue.
Thanks to Doug for finding this, though. I'm bummed that a 5 minute fix would have saved me from buying the breather, but I'm happy for everyone else that was facing (eventual) problems!
Old Apr 1, 2014 | 04:36 PM
  #70
Dameian's Avatar
Dameian
IMO the breather is the best way.... Especially if you plan on making more power in the near future!!
Old Apr 1, 2014 | 04:37 PM
  #71
Theta's Avatar
Theta
That, and it looks pretty boss.
Old Apr 1, 2014 | 04:43 PM
  #72
Translator's Avatar
Translator
^^ When you all mention a "breather"; are you referring to that little filter that is replaced with the oil cap?
Old Apr 1, 2014 | 04:47 PM
  #73
regorih's Avatar
regorih
So I dont need an $800 catch can?
Originally Posted by DOUG @ ECS
OK we have found the culprit regarding this issue guys.
The check valve, which actually is a plastic ball in the breather lines, are sticking on some vehicles. This would have started happening with stick cars too in time, but they hit higher vacuum numbers then the auto's do which pull them open again.
The slightest amount of crap on the ball and it will stick, I checked a stock car today that had one working and one stuck.
This is not a "boosted" problem, but a GM problem in my eyes, but we will probably provide a new clipped end without the check valve to eliminate the issue.
Those that are already supercharged, I suggest you just remove the check valve from the hose end, it's pretty simple to do.
You may have had this issue when you were stock, but you would not have created enough crank case pressure to see it's negative effects.
Problem solved!
Old Apr 1, 2014 | 04:54 PM
  #74
Theta's Avatar
Theta
I know it was meant to be sarcastic, but I think we'd all agree that you should have a catch can, even with the stock PCV system. Of course those are $200-$300 instead of $600.
The oil buildup is a real issue that's not going to be solved any other way.
Old Apr 1, 2014 | 04:56 PM
  #75
Theta's Avatar
Theta
Shameless plug for my own thread, but it will absolutely answer the question.
http://forums.corvetteforum.com/c7-t...es-thread.html
Old Apr 1, 2014 | 05:01 PM
  #76
Translator's Avatar
Translator
Thanks. Forgive my ignorance, but I was under the impression that a breather was not related with the catch can. Here is a simple question: If I run a centri kit on a C7 with just 7 PSI, with everything else stock; will I need, or is it recommended for me to also get the catch can/breather set-up?
Old Apr 1, 2014 | 05:04 PM
  #77
Theta's Avatar
Theta
As I said above, I don't anyone would disagree that you should use at least a catch can on these motors (especially with FI). Elite has a very nice can (the E2), but I decided to go with the LMR to eliminate any worries with pressure.
As power scales, you'll eventually overpower the stock PCV, but that takes more than a blower kit. They originally made the breather for their twin turbo system, so it's kind of overkill.
Either way, several of us would recommend having something to catch that oil.
To *WARNING* to ALL BOOSTED C7s
Old Apr 1, 2014 | 05:12 PM
  #78
runutzzzzz's Avatar
runutzzzzz
I'll buy it off you for $400.00
You never did, a $200 Catch can would work, just wouldn't look as nice and not have the same amount of volume.
Keep that oil off those valves. Then again, Meth Injection will do that too
Old Apr 1, 2014 | 05:21 PM
  #79
Theta's Avatar
Theta
Nah - I'm excited to get it back from the powder coater. I think it's going to look 10x better after that's done.
Exactly - the cans will hold less, but retain the legal PCV system. The other option is more race-oriented.
So we can justify a meth kit as preventative maintenance? Sweet!!
Old Apr 1, 2014 | 05:28 PM
  #80
runutzzzzz's Avatar
runutzzzzz
More performance and it cleans the carbon deposits.
