Backfiring in between gears?
Old Apr 27, 2014 | 01:16 PM
vampz13x's Avatar
vampz13x
Default Backfiring in between gears?
Hi all, I'm a new C7 owner. Question, when pushing the car at high RPM's and switching gears, I hear what sounds like backfiring or something from the exhaust (GM performance exhaust). I hear it's normal but wanted to check if anyone else has had this?
Old Apr 27, 2014 | 01:29 PM
gthal's Avatar
gthal
Yep... Normal. Love the sound when it does it. Although I would describe as a backfire but rather an exhaust fart
Old Apr 27, 2014 | 02:06 PM
Theta's Avatar
Theta
St. Jude Donor '14-'15
Completely normal. If you're lucky, it shoots fire. (don't worry, not in stock form)
Old Apr 27, 2014 | 10:19 PM
vampz13x's Avatar
vampz13x
Default Thank you!
thank you!
vampz13x's Avatar
vampz13x
Default Thank you!
Thank you! It's exactly an exhaust fart!
Old Apr 27, 2014 | 10:23 PM
Higgs Boson's Avatar
Higgs Boson
auto or manual trans? auto will cut timing for the shift. manual is just normal airflow sounds.
a back fire is when it fires backwards. combustion in the intake manifold. I don't think anyone has heard a true backfire on a new car in many many years. that's when you have a carburator, normally, and the EPA makes you run a fire suppressing air filter. ain't technology grand?
Old Apr 28, 2014 | 11:07 AM
LT1xL82's Avatar
LT1xL82
Fart? Maybe I should change my plate to "Silent but Deadly"
Old Apr 28, 2014 | 01:35 PM
Theta's Avatar
Theta
Here's an example of a backfire... watch the exhaust pipe.
-- @ 1:20 --
Old Apr 28, 2014 | 04:55 PM
Process Black's Avatar
Process Black
Although my description differs, I agree that it puts a smile on my face.
To Backfiring in between gears?
