Would these wheels fit
Old Apr 30, 2014 | 05:12 PM
EVL-C8's Avatar
EVL-C8
Default Would these wheels fit
I have been told that these wont fit a base C7, but they appear to have the same dimensions?
http://www.oewheelsllc.com/Wheels_3/...T#.U2FnCPldXX4
Old Apr 30, 2014 | 05:15 PM
Higgs Boson's Avatar
Higgs Boson
sure they should fit but i bet they are super heavy
Old Apr 30, 2014 | 06:16 PM
Frans96ss's Avatar
Frans96ss
St. Jude Donor '09
C6 wheels do not fit C7.... the ONLY wheels i have got to fit so far is a C5Z06 rear wheel.
Old Apr 30, 2014 | 07:37 PM
EVL-C8's Avatar
EVL-C8
Spec's are almost identical to C7 stock on my link above, what doesn't work?
FRONT WHEEL SIZE: 18x8.5
FRONT WHEEL OFFSET: 56
REAR WHEEL SIZE: 19x10
REAR WHEEL OFFSET: 79
BOLT PATTERN: 5-120.65
HUB SIZE: 70.8
Old Apr 30, 2014 | 07:47 PM
$$$frumnuttin''s Avatar
$$$frumnuttin'
From: Should this thoughtful, valuable contribution meet with no acknowledgement or 'thanks' this post----
HUB SIZE: 70.8
there's more to it than that....the design of the spokes for example....a thick spoke that is shaped inward toward the center line will most often interfere with the calipers, especially in the front.
Old Apr 30, 2014 | 08:59 PM
EVL-C8's Avatar
EVL-C8
Thanks for the clarification Hopefully somebody will make replica wheels that will fit someday? I'm not spending 5 grand on a set of wheels
Old Apr 30, 2014 | 10:36 PM
Frans96ss's Avatar
Frans96ss
St. Jude Donor '09
Brake calipers is what was hitting on the 10 diff wheels that i tried.
Old Apr 30, 2014 | 10:48 PM
greg7097's Avatar
greg7097
Use a 5mm spacer, the c6 wheel fits and the wheel is still on the hub.That's all it takes. Just check the turns on the lug nut.
Old May 1, 2014 | 07:46 AM
EVL-C8's Avatar
EVL-C8
Frans96ss, To clarify, this was on a non Z51 base Stingray package brakes?
Old May 1, 2014 | 12:42 PM
savage's Avatar
savage
Default im also into fitment
the c5z06 17x9.5 fits my non-z51 c7 front only. the 18x10.5 fit front and back. fyi, i use 295/35/17 front, and 315/30/18 rear. or 315/30/18 front and back. ps. these aftermarket(china) wheels are under $150.00 each, NEW OLD STOCK, all over the web.
Old May 1, 2014 | 02:10 PM
Higgs Boson
can you post mounted pics, especially showing the offset/fender?
Old May 1, 2014 | 04:46 PM
$$$frumnuttin'
295 up front?! are you sure about that?
Old May 2, 2014 | 07:14 AM
savage's Avatar
savage
Default yes, im sure
and sometimes 315/30/18's up front, this is the same setup i started using on my new 2002 cp. and then my 2008 vert, now my non-z51 C7. 25 plus years ago i was at a event (auto-x) in hershey pa. and seen a guy there with a yellow c4 with 315/?/ 17's front and back, he told me about contact patch and that his tires were so wide that it was like getting two tires for the price of one, you just flip the tire when its wore out middle to outer edge,
Old May 2, 2014 | 07:24 AM
savage's Avatar
savage
Default on my facebook page
please go to my facebook page to see pictures, david savage(its a picture of me with my son) and with the pic it will say work's at lion brewery, bayo's ice. at my last auto-x event someone took about 15 pictures of my car running and posted it to me. just click on the one you first see and many more are behind? it. that day i have the 17x9.5 up front(295/35/17). yes that wheel looks small but i like more tire than wheel for racing.
Old May 2, 2014 | 09:09 AM
savage's Avatar
savage
Default p.s. after i looked these pics
i ordered z51 front and rear swaybars, it felt great, but pictures dont lie!
To Would these wheels fit
