Kooks vs American Racing Headers
Old Jun 1, 2014 | 11:47 AM
Q8 c7's Avatar
Q8 c7
Im going to install my arh mid length tomorrow.MY QUESTION
DO I HAVE TO DISCONNECT THE negative wire?after installation will i have to take it to the dealer for any reprogramming?
or can we do the installation without disconnecting the battery wire?
Many thanks
Old Jun 1, 2014 | 11:05 PM
RussM05's Avatar
RussM05
I installed mid length ARH headers yesterday. Disconnect ground cable at battery. Reconnect after installation finished. Do not go to dealer for PCM reflash. Restart.
Old Jun 1, 2014 | 11:11 PM
Q8 c7's Avatar
Q8 c7
Thanks for the reply,the installation will be later today.
after i connect the battery will i need to put in a pin code for the stereo system?
Im in kuwait & i bought the car from the states,there is no warranty on it here,and the waiting list at the dealership here is till december
Old Jun 1, 2014 | 11:14 PM
Q8 c7's Avatar
Q8 c7
Any tips on the installation?
Do you feel the ho gains?or will a tune really get the hp out?
Old Jun 1, 2014 | 11:17 PM
Higgs Boson's Avatar
Higgs Boson
you don't need to disconnect your battery. all that does is reset the long term fuel trims.
Old Jun 1, 2014 | 11:26 PM
RussM05's Avatar
RussM05
When removing the large fuse block on the the passengers side to get to the exhaust manifold, disconnect the battery. There is the main positive cable there and it needs to be disconnected. You need to disconnect the battery to avoid a major electrical short.
Old Jun 1, 2014 | 11:33 PM
Higgs Boson
oh yeah, that too.
Old Jun 1, 2014 | 11:34 PM
Q8 c7's Avatar
Q8 c7
Ok i will have to disconnect only the negative wire from the battery before doing the whole job.
No need to disconnect the positive from the battery at all correct?
is there a stereo system pin code correct?
Old Jun 2, 2014 | 07:26 AM
RussM05's Avatar
RussM05
No to both questions.
Here is a hint. The driver side header goes in from the bottom. Passenger side header goes in from the top. To get the passenger-side in, you have to remove the starter.
Old Jun 2, 2014 | 07:41 AM
Q8 c7's Avatar
Q8 c7
Thanks very much.
Im going to the garage in 2 hrs & start on it.
Last question,should i remove both battery wires?or the negative only?
Q8 c7's Avatar
Q8 c7
Thanks very much.
Old Jun 2, 2014 | 07:51 AM
CPhelps's Avatar
CPhelps
Thanks very much.
Disconnecting the negative only is sufficient, as both need to be connected to complete the circuit to allow the flow of electricity. Once the negative is disconnected, the car is no longer powered.
Old Jun 2, 2014 | 07:59 AM
  #33
Q8 c7's Avatar
Q8 c7
Thats what i know,but i was worrying about the positive wire on the fuse box?so thats why i was saying disconnect the positive as well...
Old Jun 2, 2014 | 08:02 AM
  #34
Q8 c7's Avatar
Q8 c7
Off to the garage
Old Jun 2, 2014 | 08:55 AM
  #35
RussM05's Avatar
RussM05
Off to the garage
Before I installed mine, I had them ceramic coated. Its been advertised this help reduce under hood heat. Here in Central Texas, anything you can do to reduce heat under the hood is very good. I would like to hear from others whether they experienced flaking of the ceramic coating. Perhaps preparation and new materials will help. It was done with Cerakote in Titanium color.
Old Jun 4, 2014 | 07:33 AM
  #36
leadville1's Avatar
leadville1
I ceramic coated mine inside and out, I am using my car for road racing and less heat is my goal. I had 2000 degree race coat done on the inside and 1200 Cerakote done on the outside. They are beautiful and in my experience very durable I have had all my exhaust pieces coated in the past and never had an issue with it coming off.
Old Jun 4, 2014 | 01:07 PM
  #37
Cunningham Motorsports's Avatar
0Cunningham Motorsports
Former Vendor
Originally Posted by Andy@AandASuperchargers
It settled down? That must have happened when I wasn't lookin'
Oh. And to get back on topic, I've used nothing but American Racing Headers since the day Nick opened his doors. I think I might have been his first customer, or certainly close to.
There's nothing he won't do to make his product and customer service better than anyone else's.
That reminds me. I need to order a set for my car.
i got a set of mids here if you want them
To Kooks vs American Racing Headers
Old Jun 2, 2016 | 02:31 PM
  #38
Lester Richards's Avatar
Lester Richards
4th Gear
Default coating
Where did you get your coated and cost?
Old Jun 2, 2016 | 06:08 PM
  #39
robert miller's Avatar
robert miller
Default ttt
From the 2 you have said I would go with ARH 100%. But on my c7 I went with LG LT headers in mine. Robert
Old Jun 2, 2016 | 11:59 PM
  #40
C7 x 2's Avatar
C7 x 2
I just did a full write up on this when I installed ARH mid lengths on my Z06. It is here in the Tech forum. You might want to take a look as I covered some of the issues I had with the install. Good luck
