High DA
Old May 17, 2014 | 11:58 PM
shftn7's Avatar
shftn7
Default High DA
Heading to track tomorrow evening. DA is expected to be 7000+. Car is a bone stock auto on 91 pump gas. Expected time? 12.5-12.7? Anything I can do to overcome high DA? Getting a baseline before I send car off for a supercharger & headers.
Old May 18, 2014 | 12:20 AM
kp's Avatar
kp
Go to a lower elevation track, thats about it.
There are several DA calculators that are fairly close. 7000' will put you ~7-8 tenths down from sea level.
Old May 18, 2014 | 09:10 AM
W88fixer's Avatar
W88fixer
Bad deal, you’re looking at about 24.5% lower air pressure. Normally aspirated engine can’t help but to loose a lot of power. Don
Old May 18, 2014 | 11:10 AM
vegasredz062's Avatar
vegasredz062
St. Jude Donor '08
i ran 12.7 c7 z51 7 speed at 114 in 5000DA
Old May 18, 2014 | 03:43 PM
Unreal's Avatar
Unreal
12.5-12.7 would be lucky. I ran in ~7k da and went 13.0@112-113 in a 7 speed z51.
Old May 18, 2014 | 04:59 PM
Fore58's Avatar
Fore58
I ran 11.94 at 1400 in an auto
Old May 18, 2014 | 05:14 PM
Shaka's Avatar
Shaka
How did you measure DA? Is the actual altitude 7000'? Santa Fe'? Will the DA be 7000' at the time you run in the evening. You only have 9 or 10 lbs pressure before the butterfly and maybe 19 20"hg. Make sure the car is not run for an hour before the run. Start it just before the run. Push it to the tree if possible. Arrive with an empty gas tank and chill 3 to 5 gallons of gas in a container and pour it in the tank just before the run. Airate the gas with pure oxygen if you can. Measure track temp and run as late as possible into the evening. Check wind. Xwind will give you colder air. Launch at higher than normal rpms and shift at redline. Base line at a different DA is pointless even with correction. There will be slightly less drag.
How much tread is there on the tires? Run them at 20"Do a test run without a burn out. I'd rather have cold cylinder heads and intake than hot tires.
Old May 18, 2014 | 05:29 PM
vegasredz062
St. Jude Donor '08
Autos Launch better ET wise.
I power shifted every gear and could only manage a 114 trap. Car has no ***** with hot air and elevation on 91 fuel
Old May 18, 2014 | 06:23 PM
C7pimp's Avatar
C7pimp
Yesterday I trapped 111mph in DA of about 6400.
Launch was complete garbage, so I didn't even get into the 12's.
An LS2 GTO I went against only trapped 98mph for reference.
Old May 18, 2014 | 08:14 PM
shftn7's Avatar
shftn7
I measured with a DA calculator based on the track. Pressure is 29.70,
Altitude is 3800 and temp is 91 degrees. I am heading to track here in about 30 mins so I will see what they have at the track. I will report back. Friend has a 11 Camaro with bolt ons and headers and ran a
14 sec at 105.
I will add some of the other things mentioned as well and see what I can do. A lot of hanging heads out there in this heat.
Old May 19, 2014 | 12:16 PM
C7pimp's Avatar
C7pimp
14 sec at 105.
Not even breaking 13's at 105mph, just as me not breaking into 12's with a 111mph trap just means we had crappy launches.
This car launches much differently than my Mustang.
I trapped 111 in the vette and ran 13.2
I trapped 118 in my Mustang and ran an 11.6
It's all about traction and launch technique. I'm still finding that spot for the C7.
Btw, launch control on stock tires at the drag strip is worthless. It just spins off the line way too much. Way too high of rpm for a street compound.
Old May 24, 2014 | 12:21 AM
shftn7's Avatar
shftn7
Not able to run last Friday and this Friday rained out! Next week out of town so not until June now
Old Jun 7, 2014 | 10:58 PM
shftn7's Avatar
shftn7
Finally ran last night. 13.59 at 106 (came off gas). DA was 6600 ! Launch was horrible on stock tires. I cut a 2.06 60 ft time. Smoked the other guy though at least. I drop off car Monday for supercharger so my only trip to the track stock. Tires and rims are a must. Another Vette hit a 12.7 stock and letting out I would have been a 12.9 or so so still not the best driver either but I had fun.
Old Jun 8, 2014 | 12:43 AM
Fore58's Avatar
Fore58
As long as you had fun.....that's the name of the game.
To High DA
