Front and Rear Spring Removal/Install
Old Jun 10, 2014 | 09:38 AM
  #41
ect's Avatar
ect
theta what i should have asked is how can i get this level of service info. thanks eric
Old Jun 10, 2014 | 11:03 AM
  #42
Steve Snake Driver's Avatar
Steve Snake Driver
Melting Slicks<br><img src="/forums/images/ranks/3k-4k.gif" border="0">
If the expensive tool is the spring compressor (I didn't read through all the instructions), removing both lower control arms might negate having to buy the spring compressor.
Old Jun 10, 2014 | 11:18 AM
  #43
Higgs Boson's Avatar
Higgs Boson
If I ever get some coilovers shipped to me my plan is to simply loosen the sway bar link and lower shock bolt, remove the spring brackets and they should come right out. At least that's what it looks like.
Old Jun 10, 2014 | 11:30 AM
  #44
eboggs_jkvl's Avatar
eboggs_jkvl
Moderator emeritus
2015 C7 of the Year Finalist
Sounds like the same as the C6. I did that in my garage with floor jacks, bottle jack, and hand tools (sockets). Maybe 3 or 4 hours working alone.
Elmer
Old Jun 10, 2014 | 04:33 PM
  #45
Theta's Avatar
Theta
St. Jude Donor '14-'15
Ever notice the official instructions make things worse than they really are?
Anybody think that's to inflate shop time, or perhaps aid lesser-experienced techs? Just a thought...
Old Jun 10, 2014 | 04:48 PM
  #46
eboggs_jkvl
Moderator emeritus
You're probably correct. I was worried about the tension of the springs when I did my coil overs. Wheels off, and bottle jack on the spring, I just released the tension and then took off the clamps. Drop the spindle out of the way and the spring slid straight out to the side. Installed the coil overs and closed the stuff up. Hardest thing was to convince the spindle ball rod to give of it's grip of death and drop down out of the way!
Elmer
Old Jun 10, 2014 | 04:52 PM
  #47
Theta's Avatar
Theta
Side note, Elmer - I love the GIF avatar - never dawned on me to do that.
Old Jun 10, 2014 | 05:25 PM
  #48
eboggs_jkvl
Moderator emeritus
Retired old farts have lots of time to fiddle around with stuff!
Elmer
