ARH Header Install Tricks/ Help
Old Jun 4, 2014 | 07:02 PM
leadville1's Avatar
leadville1
Default ARH Header Install Tricks/ Help
Has anybody documented an install of the LT ARH headers on a Z51. I reached out to Nick as well, but haven't heard anything yet. The shop doing mine isn't a GM shop per say they are a race shop that does a lot of high performance road racers so they do have some knowledge but there must be a lot of native knowledge on this board I could share with them to assist with the installation.
Thanks in advance.
Old Jun 4, 2014 | 07:44 PM
thespymaster's Avatar
thespymaster
Originally Posted by leadville1
Has anybody documented an install of the LT ARH headers on a Z51. I reached out to Nick as well, but haven't heard anything yet. The shop doing mine isn't a GM shop per say they are a race shop that does a lot of high performance road racers so they do have some knowledge but there must be a lot of native knowledge on this board I could share with them to assist with the installation. Thanks in advance.
Nick is overseas currently and will be back next week !
Old Jun 4, 2014 | 07:46 PM
Higgs Boson's Avatar
Higgs Boson
I've read remove the starter and fuse box. Passenger side goes in from the top, driver side goes in from the bottom. Lefty loosey, righty tighty. boom, done.
Old Jun 4, 2014 | 08:04 PM
slief's Avatar
slief
Here you go. This should help.
http://forums.corvetteforum.com/c7-t...h-headers.html
Old Jun 4, 2014 | 08:54 PM
RussM05's Avatar
RussM05
Originally Posted by slief
My posting. These are mid length.
Old Jun 4, 2014 | 08:55 PM
RussM05's Avatar
RussM05
Originally Posted by Higgs Boson
I've read remove the starter and fuse box. Passenger side goes in from the bottom, driver side goes in from the top. Lefty loosey, righty tighty. boom, done.
Passenger from the top, driver from the bottom.
Old Jun 5, 2014 | 12:06 AM
Theta's Avatar
Theta
St. Jude Donor '14-'15
I've installed a LOT of headers on my car at this point...
If they're 1-3/4" or 1-7/8", they can both easily be installed from below without removing the starter or even the starter shield. They really slip right in - you just have to dodge the occasional wire bundle - nothing huge at all.
I've never gone from the top on the passenger side, but if others have, so be it.
Old Jun 5, 2014 | 07:04 AM
RussM05's Avatar
RussM05
We tried a long time to install the passenger side from the bottom but never could find the right angle. The header would not clear the frame. Anyway, removal of the starter is very easy.
Old Jun 7, 2014 | 09:51 AM
SteveDoten@ARH's Avatar
SteveDoten@ARH
Premium Supporting Vendor
Everything went well?
Old Jun 7, 2014 | 03:37 PM
Theta's Avatar
Theta
I will say there's just a certain finesse / approach to it - once you do it once, you just have it down to a science.
However, it was probably easier to do it from the top, which actually means yours was most likely a better way.
Old Jun 7, 2014 | 07:57 PM
leadville1's Avatar
leadville1
Mine haven't gone it yet was hoping for step by step instructions, this isn't a GM shop they are more of a Porsche shop but also have done some Vetes'. They run a LMP2 race team out of this shop and build GT3 race cars so they know their stuff.
Old Jun 7, 2014 | 08:22 PM
Theta's Avatar
Theta
Here's a start...
Old Jun 7, 2014 | 08:28 PM
Theta's Avatar
Theta
Intermediate Pipe:
Old Jun 7, 2014 | 08:30 PM
Theta's Avatar
Theta
And finally, the cherry on top - the article detailing install ARH headers specifically:
http://www.superchevy.com/how-to/exh...racing-headers
Old Jun 8, 2014 | 08:32 AM
leadville1's Avatar
leadville1
This is perfect thanks everybody on the board for the help....
Old Jun 8, 2014 | 11:53 AM
Q8 c7's Avatar
Q8 c7
Are these instructions for a C7?!
Forgot the removal of the fuse box/starter
Old Jun 8, 2014 | 12:43 PM
RussM05's Avatar
RussM05
Needed to remove spark plugs then the exhaust manifold heat shields to gain access to all the manifold bolts.
When installing the new passengers side, had to remove the valve cover. To do that, had to pull the alternator away from the valve cover to get to the front bolt on the calve cover. To do that, had to remove serpentine belt, remove top alternator mount bolt, loosen bottom mount bolt, the pull it way from the valve cover to get to the front valve cover bolt.
To ARH Header Install Tricks/ Help
Old Jun 8, 2014 | 12:46 PM
Q8 c7's Avatar
Q8 c7
We removed the plugs/wires/fuse box/starter & disconnected the negative wire
Old Jun 19, 2014 | 01:09 PM
jyounger74's Avatar
jyounger74
BUMPAwesome Headers great customer service
Old Jun 19, 2014 | 10:16 PM
RussM05's Avatar
RussM05
ARH shipped new cats and O2 spacers. They arrived yesterday and we installed them tonight.
I cleared the codes and drove home about 20 miles. No codes yet but not enough miles to be sure.
ARH responded quickly and let me know what they thought was causing the CEL. So I give them high marks for customer service.
