The following How-To covers the explanation of how to Remove/Replace the Lower Rear Bumper Fascia and includes specifications, schematics, etc.
These How-To guides are neither endorsed by or property of Corvette Forum or myself in any way/shape/form. All liability stemming from any actions taken in relation to these guides is solely placed upon the user.
This is the official and proper way to remove the lower rear valance.
I purchased the WeaponXmotorsport diffuser (ie a replacement for the rear lower fascia piece), and this is the instruction received:
Basically you must remove the entire rear end of the car to replace the lower piece correctly.
If you were able to install the lower and get the vents aligned properly with just the lower off, you're the man! Since the carbon is not flexible like the urethane, it is harder to get lined up. The vents are tough to position properly since the tabs need secured from the back so they do not move as well.
I will tell you the Z06 grills are much better constructed than the flimsy LT1 grills.
In addition to what is mentioned in the first diagram, you also need to remove two screws that hold the exhaust surround in place in order to remove the lower fascia.
please help if you can. I’m planning on replacing my z51 spoiler and replace it with another different spoiler...By chance do you have instructions for removing the Z51 spoiler?
I searched everywhere for information on if the entire bumper has to be removed on the 2014-2016 rear end to repaint the bottom half. Well good news you don't have to do very much to get it off.
1. Remove the ten 7mm bolt on bottom.
3. Remove the two 10 mm bolts above the exhaust.
4. Pop off the mud flaps and remove the two 15 torx screws on each side.
5.On the bottom edge of bumper by the wheel pop the bumper loose from the upper part of the facia separating the two colored sections.
6. Now you can put your hand under the bumper and pop the red reflectors off the back.
7. Lastly remove the two 10 mm bolts on each side where the reflectors were and you are done. The bumper bottom will fall off in your hands.
Total time is less than 30 min and you can do by yourself. Then you can get the bottom painted. Installation is easier wish I had video taped it but you won't need that anyway. Good luck. Now mine is color coded to rest of car
Reason: Pictures
This is great information as I'm considering pulling the cat-back exhaust to have the tips powdercoated. Removing the lower fascia doesn't look difficult at all.
