How-To: Remove/Replace Steering Wheel
Old Jun 15, 2014 | 04:23 PM
Theta's Avatar
Theta
St. Jude Donor '14-'15
Default How-To: Remove/Replace Steering Wheel
The following How-To covers the explanation of how to Remove/Replace the Steering Wheel and includes specifications, schematics, etc.
These How-To guides are neither endorsed by or property of Corvette Forum or myself in any way/shape/form. All liability stemming from any actions taken in relation to these guides is solely placed upon the user.
We hope you will find these guides useful.
CAUTION: THIS INVOLVES WORKING WITH THE SIR/AIRBAG SYSTEM. YOU MUST EXERCISE THE UTMOST CAUTION AT ALL TIMES WHEN WORKING AROUND THE SIR/AIRBAG SYSTEM.
PLEASE NOTE THAT, AS LISTED, THE SIR/AIRBAG SYSTEM RETAINS POWER FOR UP TO 2 MINUTES AFTER THE NEGATIVE CABLE IS DISCONNECTED. PLEASE APPLY THE BRAKES FOR AT LEAST 2 MINUTES AFTER DISCONNECTING THE CABLE, AS THIS AIDS THE DISCHARGE PROCESS.
AGAIN, WE (CORVETTE FORUM), MYSELF, AND ALL INVOLVED AGENCIES ASSUME NO LIABILITY FOR THE DAMAGES OR INJURIES THAT MAY OCCUR WHILE WORKING ON THE SIR/AIRBAG SYSTEM. PLEASE EXERCISE CAUTION.
Old Jun 15, 2014 | 04:24 PM
Theta's Avatar
Theta
Theta's Avatar
Theta
Theta's Avatar
Theta
Old Jun 15, 2014 | 04:25 PM
Theta's Avatar
Theta
Theta's Avatar
Theta
Old Aug 11, 2016 | 01:50 PM
cbxturbo's Avatar
cbxturbo
Would someone please tell how to remove/replace the trim in the c7 steering wheel. (around the air bag, switches etc...one piece)
Old Aug 11, 2016 | 07:50 PM
markcz's Avatar
markcz
If you're asking about the silver trim piece, once you have the airbag out it just pops off with a bit of prying. Just be careful not to use a tool that will bend the thin edges of the metal (or at least start on the bottom side where it won't be seen).
Old Aug 11, 2016 | 08:30 PM
cbxturbo's Avatar
cbxturbo
Many thanks!
Old Dec 10, 2016 | 09:12 PM
blown81bu's Avatar
blown81bu
Old Jan 1, 2017 | 04:52 PM
ZorenZ51's Avatar
ZorenZ51
Originally Posted by blown81bu
Any videos or step by step pictures available on how to do this DIY?
What tools needed? I do plan to change the steering of my z51 to a flat D type.
Old Jan 3, 2017 | 09:03 PM
E.T.D. Corvettes's Avatar
E.T.D. Corvettes
C7 & C8 Events Correspondent
2020 C8 of the Year Finalist - Unmodified
2020 Corvette of the Year (track prepared)
C7 of Year Winner (appearance mods) 2019
2017 C7 of Year Finalist
2015 C7 of the Year
St. Jude Donor '14-'15-'16-'17-'18-'19
More info in this thread - Steering Wheel Swap Thread
Old Mar 1, 2017 | 09:14 PM
Steve Snake Driver's Avatar
Steve Snake Driver
Melting Slicks<br><img src="/forums/images/ranks/3k-4k.gif" border="0">
Approximately how much force is required to apply through the two little holes to pop the airbag. I tried and tried, but it began to feel like it was excess force. I changed the wheel trim on a 14 C7 and don't remember it requiring so much force to free the airbag clips.
Old Mar 6, 2017 | 10:25 AM
markcz's Avatar
markcz
It doesn't really take any force at all. You just need to push the tab over a bit and the air bag should pop off almost by itself.
If you're at the wrong angle with your tool you could easily miss the tab. IIRC it needs to go in pretty much parallel to the axis of the steering column.
Old Mar 6, 2017 | 09:50 PM
Z06 1of38's Avatar
Z06 1of38
Where did Theta go? He was a very knowledgeable contributor.
Old Apr 25, 2018 | 06:35 PM
roysvette's Avatar
roysvette
I have a carbon fiber trim ring as a replacement and also a pair of coloured paddles to replace the stock black ones. Does anyone know how I go about replacing them? Do I have to remove the steering wheel to do the swap?
Thank you.
Old Apr 26, 2018 | 05:39 PM
NinjaZX14r's Avatar
NinjaZX14r
Make sure you disconnect negative side of battery, wait 5 minutes...put your foot on the brake a few moments..then you should be good to go. It is lots easier than it looks..once the airbag is out....the spoke easily pulls off disconnect two plugs at 4 and 7 o'clock, then the Star Nut....wheel slides right off.
NW
To How-To: Remove/Replace Steering Wheel
