Tuning E92 driver demand torque
Old Jul 31, 2014 | 10:12 AM
typhoon186's Avatar
typhoon186
Default Tuning E92 driver demand torque
I've been trying learn about the driver demand on the E92 (C7 LT1 and truck L86). As I understand, HP Tuners has sophisticated tuning around the driver demand. Diablosport In-tune appears to only have the ability to turn torque management on or off on the ecm and/or tcm. What is the main differences between these two tuning methods? Is the Diablosport leaving a lot untapped potential that HPTuners can access or not? Is driver demand completely different that torque management or basically the same?
Old Jul 31, 2014 | 10:25 AM
Mike@DiabloSport's Avatar
Mike@DiabloSport
Supporting Vendor
Driver demand and TM are not the same really.
We do allow end users to adjust the driver demand on C7's for better throttle response in our handhelds.
Old Jul 31, 2014 | 11:02 AM
Higgs Boson's Avatar
Higgs Boson
the driver demand logic is part of a bigger engine control method known as torque management.....
torque management control everything now, idle to full throttle to air conditioning to transmission shifting, etc. driver demand is a part of that system.
Torque Based Logic
Old Jul 31, 2014 | 11:10 AM
jpshark's Avatar
jpshark
Torque Based Logic
Great info HB
Old Jul 31, 2014 | 02:11 PM
typhoon186's Avatar
typhoon186
Torque Based Logic
Does that mean that turning off torque management eliminates the driver demand restrictions also?
Old Jul 31, 2014 | 04:02 PM
Higgs Boson
There is no such thing as turning off torque management anymore. The term "turning off torque management" is sort of an old school (a few years ago) reference to eliminating the power restrictions put in place by retarding timing or closing throttle during shifts or limiting power output in the same way above certain limits.
Things have changed with the E78 and the E92 controllers. Driver Demand is not a restriction. It is the first step in telling the computer what your intentions are, then it tells the engine what to do based on it's interpretation of your intention.
Now you alter the ECUs interpretation (along with optimizing spark and cam timing and air fuel ratios, etc).
Old Jul 31, 2014 | 07:33 PM
typhoon186's Avatar
typhoon186
Thanks, great info. Sounds like I still have a lot to learn. So does the Diablosport IN-Tune for the C7 have an option listed to turn off and on torque management on the ecm and tcm like it does for the 2014 GM truck with the 6.2 L86? If so, what is that option doing? The IN-tune for the truck does not have anything listed at driver demand. I think it has the E92 also and would have driver demand.
To Tuning E92 driver demand torque
