Engine Cover
Old Aug 6, 2014 | 12:09 PM
EVL-C8's Avatar
EVL-C8
Default Engine Cover
What is the procedure to remove the engine cover?
Old Aug 6, 2014 | 05:29 PM
LT1_E85_Corvette's Avatar
LT1_E85_Corvette
I would like to know this as well
Old Aug 6, 2014 | 10:03 PM
TEXHAWK0's Avatar
TEXHAWK0
There is a detailed description, with photos, from one of the vendors that sells aftermarket covers on the forum...
I will post link if I find it.
http://forums.corvetteforum.com/c7-t...r-removal.html
The simple explanation is that the fuel rail covers just snap onto posts, and the plenum is held on by the bolts/studs that the fuel rails mount on.
Snap the side covers off, then remove the 4 bolts on the plenum, and disconnect wiring harness that runs through side opening in plenum.
To Engine Cover
