arrow on dash
Old Aug 19, 2014 | 04:06 PM
ltfun's Avatar
ltfun
Default arrow on dash
whats the arrow on the dash c7 left side seems to be lite am I missing what this is for ?
Old Aug 19, 2014 | 04:29 PM
eboggs_jkvl's Avatar
eboggs_jkvl
Moderator emeritus
2015 C7 of the Year Finalist
4 way hazards?
A little more detail as to the location would be helpful.
Elmer
Old Aug 19, 2014 | 04:44 PM
ltfun's Avatar
ltfun
there is 4 arrows as I look at dash cluster top bottom left and right small and the left one seems to be lite not the flasher arrows they are green these are small and white
Old Aug 19, 2014 | 04:58 PM
xp800's Avatar
xp800
The arrows for navigating the DIC modes/features? Arrow pad on steering wheel.
Start on page 5-7 of the manual.
Old Aug 19, 2014 | 05:36 PM
ltfun's Avatar
ltfun
ty ill have to check it out thanks again
Old Aug 22, 2014 | 01:37 AM
tblu92's Avatar
tblu92
St. Jude Donor '13-'14-'15
The arrows are there to configure the dash--The left arrows configure which group you want to change---Starts with Info then Performance and about 5 more
To select the group you press the center button--Then you can change the dash display according to what you want to see---The performance mode has the 0-60 timer in it as well as the car balance bubble-- G-Force meter as well as other options---The Info group allows you to change the visible gauges--oil press--oil temp--trans temp --V8-V4 mode--Instant MPG and Avg MPG etc
Old Aug 22, 2014 | 07:23 AM
ltfun's Avatar
ltfun
Default arrows
thanks knew all that stuff but didn't understand the arrows and why its lite ok thanks again
To arrow on dash
