Diablo Trinity Issues
Old Sep 17, 2014 | 08:32 AM
mjw930's Avatar
mjw930
Default Diablo Trinity Issues
I picked up a used unmarried Trinity and have noticed 2 issues.
1. Even after resetting it to factory defaults none of the predefined gauge clusters are available in the monitoring section, only clusters I build and save.
2. Even with the device set to manual transmission it will not let me change the CAGS setting (skip shift) for a modified stock tune.
The device has been updated to the most current software and works fine to save the stock tune and upload the canned tunes. The canned tune has CAGS disabled but again, does not provide an option to toggle it on or off.
Hopefully Mike will read this and respond.
Old Sep 17, 2014 | 09:07 AM
DOUG @ ECS's Avatar
DOUG @ ECS
Premium Supporting Vendor
From: Providing the most proven supercharger kits for your C5/6/7 609-752-0321
Mike will be around shortly to help you out, Diablo has great customer service.
Old Sep 17, 2014 | 09:29 AM
mjw930's Avatar
mjw930
Yes, that's one of the reasons I do business with them. I would normally have simply emailed them but I figured the answers may help out others here.
Old Sep 17, 2014 | 12:09 PM
Mike@DiabloSport's Avatar
Mike@DiabloSport
Supporting Vendor
1. What is the software version under options/show information?
Does the tool ask if you want to restore default layouts?
There ought to be 2 or 3 preloaded ones to choose from.
2. CAGS should be disabled by simply loading one of the preloaded tunes. Are you still being forced from 1st to 4th?
Old Sep 17, 2014 | 03:27 PM
mjw930's Avatar
mjw930
Version v.1r13a
Yes, the tool asks if I want to re-install the defaults, I respond "Yes", it waits for a few seconds then comes right back to the "No gauge layouts were found" screen.
CAGS is disabled with the preloaded tunes, I am looking for an option to disable it on a modified stock tune, just like you can disable AFM/DOD.
Old Sep 17, 2014 | 03:41 PM
Mike@DiabloSport
Supporting Vendor
Originally Posted by mjw930
Version v.1r13a
Gotchya.
When you selected your vehicle, 14/Chevy/Corvette/6.2, it should have selected the layouts we designated for that application.
Will sort this out.
I'll ask about getting the CAGS switch added as well
Old Sep 17, 2014 | 03:42 PM
Mike@DiabloSport
Supporting Vendor
If you go back to options, and select say a 2014 Sierra, you should see the gauge layouts.
Old Sep 17, 2014 | 04:34 PM
mjw930's Avatar
mjw930
Mike,
Yep, when I select Silverado I get some gauge options.
Here's the list of files on the system, looks like the C7 specific gauges didn't make it to the file and the base GM Gas gauges aren't linked to the C7 config.
Old Sep 17, 2014 | 04:39 PM
Mike@DiabloSport
Supporting Vendor
Mike,
Attachment 47827523
Yup, we missed them somehow....but I have a new build going now to add 15 stuff and we've confirmed the layouts will be there for 14 or 15 C7 selections at that point
Old Sep 17, 2014 | 04:46 PM
mjw930's Avatar
mjw930
Great, thanks.
To Diablo Trinity Issues
