What video camera, and how/where mounted
Old Dec 15, 2014 | 01:52 PM
NTMD8R's Avatar
NTMD8R
Default What video camera, and how/where mounted
OK, my 2014 does not have PDR.
And, as I understand it, installing the 2015 PDR system is a no-go.
So, what after-market video camera would compare with the one
from the PDR ?
And, how/where would I mount it?
And, how about encompassing measurements of speed, rpm, g-force, etc., etc. ?
Any thoughts, recommendations, or ????
Old Dec 15, 2014 | 03:40 PM
eboggs_jkvl's Avatar
eboggs_jkvl
Moderator emeritus
2015 C7 of the Year Finalist
Subscribed
Old Dec 15, 2014 | 07:25 PM
VThokies's Avatar
VThokies
Solo DL with OBDII interface and smarty cam?
Old Dec 15, 2014 | 07:59 PM
ZEEGS's Avatar
ZEEGS
I bought this dash cam on amazon because it had a motion sensor. I was driving to a buddies golf trip and wasn't that comfortable leaving my new ride in the parking ramp. It was very cheap and the video is good.
Amazon.com : Black Box B40 A118 Stealth Dashboard Dash Cam - Covert Versatile Mini Video Camera - 170° Super Wide Angle 6G Lens - 140°F Heat Resistant - Full HD 1080P Car DVR with G-Sensor Night Vision Motion Detection - NT96650 + AR0330 : Electronics Amazon.com : Black Box B40 A118 Stealth Dashboard Dash Cam - Covert Versatile Mini Video Camera - 170° Super Wide Angle 6G Lens - 140°F Heat Resistant - Full HD 1080P Car DVR with G-Sensor Night Vision Motion Detection - NT96650 + AR0330 : Electronics
The good:
It was cheap
It came with a long cord so that it can be plugged into the trunk outlet.
Good quality video
Motion sensor
It is very small and mounts behind the rear view mirror.
The not so good:
The instructions are terrible. You need to mess with it for an hour to figure it out.
No speed, GPS, or other car data
Sample video. Sorry the radio was on.
Old Dec 15, 2014 | 09:15 PM
runutzzzzz's Avatar
runutzzzzz
Here's my 14' with a Blackvue installed in the PDR location.
Camera is wifi so I can stream on my iPad or iPhone.
Records GPS info and the quality is very good. Also has an option for a rear camera.
Old Dec 15, 2014 | 10:25 PM
NTMD8R's Avatar
NTMD8R
Zeegs,
Thanks for the info... looks good.
I wonder if we can tap into the mirror electronics for power.
Nutzzzzz,
more info please... (name, model, where available (link if possible), etc., etc.))
And a sample of video taken, if possible.
Old Dec 16, 2014 | 10:17 AM
eboggs_jkvl
Moderator emeritus
Would that interfere with my V1 mounted under the mirror?
This is what I did for my V1: https://www.corvetteforum.com/forums...post1586672645
Elmer
Old Dec 16, 2014 | 10:35 AM
jwbert's Avatar
jwbert
I have a GoPro mounted to the shark bar harness bar between the seats, and an iphone 6 running Track Addict app that controls the gopro and also pics up data from the go point BT1 OBDII sending speed, g's etc to the track addict video via blue tooth. Track addict uses WiFi to control the GoPro so you need to use a OBDII sender that
uses Blue Tooth, not WiFi The iphone is mounted to a Ram suction mount with iphone holder attachment. It all starts running when you
reach 10mph on the track, Track addict uses GPS and has various tracks loaded as well, and once you mark the start/finish line, it keeps track of that for timing purposes. Everything can be powered by mini usb cords so batteries not a problem. (GoPro with WiFi running is esp
hard on it's battery.
Old Dec 16, 2014 | 11:10 AM
eboggs_jkvl
Moderator emeritus
I found this while doing research.
$99.99 on Amazon
Amazon.com : E-PRANCE Mini 0803 Car DVR Recorder Ambarella A7LA50D Chip Full HD 1296P(Upgrade Mini 0801) -Come with E-PRANCE LOGO : Car Electronics Amazon.com : E-PRANCE Mini 0803 Car DVR Recorder Ambarella A7LA50D Chip Full HD 1296P(Upgrade Mini 0801) -Come with E-PRANCE LOGO : Car Electronics
I have the 12v up there already for my V1 and I might be able to tap the wire for switched power to the camera.
Looked more: No GPS, no speed notation.
Elmer
Old Dec 16, 2014 | 11:59 AM
NTMD8R's Avatar
NTMD8R
JwBert,
I had my camera mounted (in my C6) to my rollbar, but that
made the viewing area difficult, because it was so far back that
it included much of the dash and windshield surround.
So I am looking for something that mounts to the windshield, in front of the mirror.
Elmer,
looks great.
How did you provide the 12v for your V1 ?
Old Dec 16, 2014 | 12:16 PM
eboggs_jkvl
Moderator emeritus
Originally Posted by NTMD8R
JwBert,
So I am looking for something that mounts to the windshield, in front of the mirrot.
Elmer,
looks great.
Ran a line down to the console and hooked it up to the cigarette plug in the console.
Elmer
Old Dec 16, 2014 | 01:10 PM
Greg Quillen's Avatar
Greg Quillen
I use GoPro Hero 3 Black edition .. its great and you can see and control it with your phone..
VBox Performance Box for Gs, and performance data.. (http://www.vboxmotorsport.com/index....performancebox )
if i want ECU data i plug in my HPTuners Scanner (http://www.hptuners.com/products/vcmscanner.php )
I put it together with RaceRender 3 (http://racerender.com/RR3/Features.html )
Old Dec 16, 2014 | 02:27 PM
jwbert's Avatar
jwbert
JwBert,
Elmer,
looks great.
I catch the up front stuff with the forward camera in the iphone and the gopro being so wide angle catches hand work and so forth inside the car. Work for me.
Old Dec 16, 2014 | 08:44 PM
runutzzzzz's Avatar
runutzzzzz
Zeegs,
Nutzzzzz,
It required me taking the camera housing off and cutting a little inside the housing part. I ran power straight back to the fuse block.
Not my car but here's a sample video. It's 10x better than the PDR.
Elmer
I'm not sure, if it doesn't interfere with the stock PDR, it will be fine.
Old Dec 17, 2014 | 11:56 PM
Zulu51's Avatar
Zulu51
St. Jude Donor '15
Take a look at Harrys GPS Lap Timer App for both iPhone and Android. Might fit the bill especially if you are on the track.
http://www.gps-laptimer.de/Home.html
Old Dec 18, 2014 | 10:32 PM
NTMD8R's Avatar
NTMD8R
Thanks Zulu,
good link.
Now, if I can use a camera recommended by others above,
(not the iPhone camera) with Harry's software
on my iphone, with an external GPS (as recommended by Harry),
and an OBD II plug/dongle (as recommended by Harry),
this might be a great solution.
Harry's software is $20.
A better GPS is about $150,
an OBD II dongle is about $100,
and a "better" camera is about $150. (I prefer the small tubular ones).
If I can make this all work with Harry's software.... whoo boy.
Old Dec 19, 2014 | 03:22 PM
GTPprix's Avatar
GTPprix
Well PDR retrofit is definitely possible as we've supplied the custom programming to make it happen for a 14 however it IS considerably expensive from what the customer told us. I guess it depends on how bad you want it?
To What video camera, and how/where mounted
Old Dec 19, 2014 | 04:50 PM
Greg Quillen
To how expensive and does it log all ecu data to be seen on cosworth program?
Old Dec 19, 2014 | 10:24 PM
NTMD8R's Avatar
NTMD8R
Originally Posted by greg quillan
to how expensive and does it log all ecu data to be seen on cosworth program?
+ 1
Old Dec 20, 2014 | 04:26 PM
CRABBYJ's Avatar
CRABBYJ
Unmodified C8 of the Year 2021 Finalist
2018 C7 of Year Finalist
$99.99 on Amazon Amazon.com : E-PRANCE Mini 0803 Car DVR Recorder Ambarella A7LA50D Chip Full HD 1296P(Upgrade Mini 0801) -Come with E-PRANCE LOGO : Car Electronics
Elmer
I have that one and it is mounted just in front of my C7 mirror with felcro for easy removal and use also in my DD. It is great, small and can take at least a 32 GB Mini SD card. I think without that card there is 8 GB internal.
Love using the 1080p resolution (1296p possible) there is another model that has GPS. Look here:
Amazon Amazon
