How-To: Remove/Replace Rear Quarter Panel (Fender) - Driver's Side
Old Dec 21, 2014 | 03:25 AM
Theta's Avatar
Theta
St. Jude Donor '14-'15
Default How-To: Remove/Replace Rear Quarter Panel (Fender) - Driver's Side
The following How-To covers the explanation of how to Remove & Replace Rear Quarter Panel (Fender) - Driver's Side and includes specifications, schematics, etc.
These How-To guides are neither endorsed by or property of Corvette Forum or myself in any way/shape/form. All liability stemming from any actions taken in relation to these guides is solely placed upon the user.
We hope you will find these guides useful.
Theta's Avatar
Theta
Removal of the rear quarter panel requires the rear fascia and wheelhouse cover(s) to be removed. Please follow the guide here to complete this task:
https://www.corvetteforum.com/forums...er-fascia.html
Additional pre-requisites:
Old May 17, 2015 | 02:24 PM
Car54's Avatar
Car54
Hi Theta
The procedure to remove the driver's side rear quarter panel says to remove the wheelhouse liner. I am thinking that is to be able to get to the clamp at the base of the filler tube. Do you have that procedure that you can post....how to remove the drivers rear wheelhouse liner.
thanks
bill
Old May 17, 2015 | 05:05 PM
Theta's Avatar
Theta
Sure thing - here you go:
Old May 17, 2015 | 05:08 PM
Car54's Avatar
Car54
Hi theta
Thanks. I really appreciate it.
Bill
Old Jun 22, 2015 | 10:27 PM
SharkAttack15's Avatar
SharkAttack15
does the front fender fit on a stingray z51 the fender guards on the zo6 ?
Old Jan 5, 2019 | 07:25 PM
badhabit_wb's Avatar
badhabit_wb
FWIW you don't have to completely remove the rear fascia to get the fender off. You can remove the tail light bezel and take the one screw out there, take the molding off under the hatch and remove those screws, and take the two screws off on the tail pipe bezel. Once that's done you can pop out that corner of the fascia and have plenty of room to take out the screws holding the fender on. The fender liner does need to come out but that's really easy and it will give you a great view of the underside of things. Also you don't have to remove the fuel filler pipe. You have to disconnect the wire going to the fuel filler door and remove one hose and that will all slip out over the fuel filler pipe. Cheers.
Old Jul 7, 2020 | 09:43 AM
hootowlc7's Avatar
hootowlc7
Getting ready to remove my drivers side rear quarter to repair a crack. Thanks for the info all!
To How-To: Remove/Replace Rear Quarter Panel (Fender) - Driver's Side
