No Lift Shift
Old Jan 14, 2015 | 12:37 PM
Higgs Boson's Avatar
Higgs Boson
It is known as Launch Control and all you have to do is read the Owner's Manual to see how it is done. GM put it Corvettes in 2010 to compete with BMW, Porsche and other high end cars so it has been around for a while. As long as you keep your right to the floor on the shift it will work. Chicken out and lift your foot and it drops out of Launch Control because there is no way for the car to know why you lifted your foot.
Bill
So a flat foot shift from 3rd - 4th is called Launch Control? I thought it was called No Lift Shift.....at least that is what it's called in the tune.
Old Jan 14, 2015 | 02:02 PM
rob03zo6's Avatar
rob03zo6
That is no lift shifting or speed shifting if done at the right rpm eliminates the use of the clutch, This can only be done on a roll. The launch control is a from a dig or a stop, you rev engine drop clutch and traction controls and stabilization take over and the computer controls the lanch after that.
Old Jan 14, 2015 | 02:48 PM
Seannyc's Avatar
Seannyc
So can we power shift it without useing launch control im tryin to figure this out or does it have to be used with launch control
Old Jan 14, 2015 | 03:41 PM
Higgs Boson
you can power shift without launch control.
Old Jan 14, 2015 | 06:08 PM
Seannyc's Avatar
Seannyc
Old Jan 14, 2015 | 10:32 PM
Z_Man's Avatar
Z_Man
they are two completely different things.
I'm well aware they are different. Just asking what everyone's thoughts are on one vs the other from a performance perspective. Sorry I wasn't more specific. Which one do you like most and why?
Old Jan 15, 2015 | 12:17 AM
Higgs Boson
launch control slows down a driver that knows how to launch
no lift shift makes everyone faster.
Old Jan 15, 2015 | 11:51 AM
ziominix's Avatar
ziominix
So the no lift shift aka power shift does work without engaging launch control? The computer still holds rpm? Or are you just saying it's possible to do it but the computer won't intervene to make it "safer" to no lift shift unless launch control was used? That's the way I understood it but would be happy to be wrong on this.
Old Jan 15, 2015 | 11:53 AM
Higgs Boson
No Lift Thread
Old Jan 15, 2015 | 12:50 PM
ziominix's Avatar
ziominix
