2015 A8 torque convertors
Old Jan 21, 2015 | 12:50 AM
123sugey's Avatar
123sugey
Dig
Good info
Old Jan 21, 2015 | 09:39 AM
Circle-D's Avatar
0Circle-D
Former Vendor
Thought I would help out with some OE pics of the new 8L90 converter. It is what I call a twin disk lock up clutch, basically a double sided clutch for more holding capacity - same as the 2014 6L80 C7. It is what GM is calling a dual face clutch. The converter still has the Pump/Stator/Turbine for the fluid drive of the converter just like the 6L80 and 4L60 conventional converters. The big upgrade for this converter is the dual damper design, able to absorb more drive line NVH so they can bring on the clutches even earlier and slip them more. Essentially a damper attached to a damper, very cool design. Definitely going to be a challenge for the aftermarket to manufacture the hardware and then capability to tune a performance stall converter for the 8L90. We will figure it out, just give us some time.
Chris
Old Jan 21, 2015 | 11:31 AM
Higgs Boson's Avatar
Higgs Boson
Originally Posted by tblu92
ALSO------Here is a magazine article where both GM C7 transmission engineers were interviewed---
They describe the new innovations on both the manual trans and auto
GM actually calls the converter a "DUAL FACE CLUTCH"
But are careful not to call it a dual clutch because it is not-- But is a very close version----
EFILIVE on the other hand calls it a "CLUTCH TO CLUTCH" (as I maintain) again not dual clutch on purpose beacsue it is not but more similar in verbage to "DUAL FACE" as GM describes.
A dual clutch converter uses 2 separate clutch plates
A clutch to clutch or dual faced converter uses 1 plate with clutch material on both sides
http://www.superchevy.com/how-to/131...rack-mode.html
Chris
At the end of the day, it is still a torque converter, which is great for drag racing, but I'll pick the stick every time for hill country, canyons, and road course work.
Old Jan 21, 2015 | 11:42 AM
Shaka's Avatar
Shaka
The big upgrade for this converter is the dual damper design, able to absorb more drive line NVH so they can bring on the clutches even earlier and slip them more. We will figure it out, just give us some time.
Chris
Only low torque downshifts although I haven't heard it or seen it on any videos yet. High torque shifts, slippage is in the TC compressor and turbine blades. All other slippage in gearbox clutches and TC clutches is kept to an absolute minim in full throttle shifts like most modern autos do. Except for the ratios, I think the tranny is a winner once it is tuned right.
LaFerrari's DCT stays alive with spirited driving buy engine management. I don't see why the TC clutch in the C7 can't stay engaged in Sport mode at all times with fuel interruption only during shifts, especially with DI. This will keep temps down.
No reason that it can't run like this Yamaha tranny.
https://www.youtube.com/watch?x-yt-t...84359240#t=191
Old Jan 26, 2015 | 08:37 PM
tblu92's Avatar
tblu92
St. Jude Donor '13-'14-'15
Chris
Thanks !!
Old Aug 11, 2017 | 03:04 PM
chevyfanatic's Avatar
chevyfanatic
Originally Posted by glass slipper
No, it is not called a "clutch to clutch torque converter" It's called a "squashed" torque converter because it has a "flattened" appearance compared to "old style" torque converters. What you're referring to is the clutch to clutch shifting architecture of the transmission itself when it changes gears. Basically, everything in your post is BS.
There is a lockup clutch inside the torque converter that engages as early as 2nd gear that eliminates the "slower/sloppier" action you're talking about. GM uses a pulse width modulated signal to release/engage the lockup clutch at low RPM to allow as much as 100 RPM "slippage" to eliminate the vibrations from AFM. GM has used this feature for over 20 years. Porsche finally copied the GM design for their PDK to allow slippage of the clutch at low RPM to eliminate vibrations.
fantastic info. didnt know anyone from Bahrain was soo knowledgeable. lol
Cunningham motorsports says they can unlock the A8 to make it shift faster. they did it with their maro.
Old Aug 13, 2017 | 10:13 PM
lakemg's Avatar
lakemg
^^^^Holy thread revival...many folks can tune it now...last post was from January 2015 when not a whole lot of A8s were on the road...
Old Oct 20, 2017 | 07:42 PM
blown81bu's Avatar
blown81bu
FTI and Circle D is making converter for A8s
Old Oct 20, 2017 | 08:29 PM
Mike Mercury's Avatar
Mike Mercury
Rather than copying the converters used in foreign super cars (which are very pricey) and are called a "dual clutch" design...
so that no one confuses DCTs with the discussion at hand...
DualClutchTrannies are not automatics; they are manual transmissions with solenoid operation (making them appear to be autos). The clutches are also solenoid operated; one for odd numbered gears, the second for even numbered gears.
Although the DCT it is a manual transmission at heart, there is no torque lost during shifts, as both clutches are kept engaged during the very quick shift sequence.
Old Oct 21, 2017 | 11:54 AM
davepl's Avatar
davepl
Rumors are that at some point the Corvette
will go to the dual clutch design as it is far superior
It's not clear to me that it's "far superior". The actual shifting is already clutch to clutch, like a DCT. The coupling is positive and mechanical at most loads other than WOT.
So it's not like I sit around saying "When we get a real DCT then we'll finally be able to..." because I don't actually know how to complete that sentence!
Do you have a link or diagram or animation on that one? That's not how I understand it, but won't argue because I'm not certain.
