Boosted - Breather / Catchcan
Here is my Rx Stage 2 Catch Can and
1LE Style Clean-Side Separator.
Installed during November. Not many miles since.
I do not smell fumes and the intake is clean.
The can does not have oil.
I can not give you a recommendation, until spring.
Okay.....now it is spring....no oil in catch can after 700 miles.....
No fumes in the cabin, I can now recommend....
Now it is fall, after 3,000 more miles, I have collected 5 ounces in the catch can.
The website is: http://www.revxtreme.com
The RX design was the most complex by far.
I have been very pleased with my setup and would definitely recommend their setup.
Someone thst runs the LMR or Lashway tell me...how bad are the fumes with it releasing to the atmosphere all the time? Is it unbearable?
Ron at VR mentioned adding some hose onto the breather outlets and basically remotely locating the filters to see how it works. If they could be moved further away from the firewall it makes sense it could reduce the venting into the cabin. Next time the car is on my lift I'm planning to find a location to relocate the filters to.
In short, on my build, the fumes are absolutely awful (with recirc or not). If you open the hood to look at what it's putting off at rev, or even near WOT, it's a ton of smoke. My filters are yellow like they were stained with nicotine for 20 years.
Now, I love the can, and I love the design, etc... I just have to get those fumes away. I've been working on this design on and off for about a month now, and so far, it's going very well. I've found a good source for the silicone elbows and aluminum T adapter. It's been more of a sizing question regarding -12AN (3/4") vs -16AN (1") for the output line running to the bottom of the bay. Not sure just how much is really needed, but if you factor max flow on the 2 -10AN and 2 -6AN, you end up with around 1". Now I doubt that would ever occur (we're talking blow-by here), but I've picked Ron's brain about this for a few weeks now going back and forth. We're leaning towards the -12AN option.
I was planning to document the design and give a part list, etc. The total project with a proper K&N shielded filter at the bottom is looking like less than $100 for everything, and the bulk of that is the 3/4" silicone hose and lower filter. I've sourced the upper adapters at a very reasonable price. Just have to do a little cutting on the silicone elbows.
Nothing came out of my drain wheni checked it yesterday however the drain isn't completely on the bottom. We did a little more racing last night so today I intend to remove the unit and see exactly how much is in it or at least unbolt it to get the drain at the lowest position possible.
You might want to contact RX and ask for the owner. He has done significant research for years on this issue. As an engineer you will be impressed with his knowledge. It might save you from having to re-invent this particular "wheel".
Jim (born and raised in St. Louis)
my personal experiece with this layout was oil EVERYWHERE in the air box, dripping down the undersides of the car, on the air filter, in the intercooler in the blow off valve, and it stunk. previous owner had a second air filter just to deal with this issue.
you are very lucky, i would encourage anyone to take a look for themselves vs. assuming everything is a-ok.
